StarTech.com 2x1 HDMI VGA to HDMI Converter
Quicklinx: B458BTBS Mfr#: VS221VGA2HD
£75.10 ex VAT
£90.12 inc VAT
Share an HDMI display/projector between a VGA and HDMI audio/video source, with automatic and priority switching. The VS221VGA2HD HDMI & VGA Auto Switch lets you connect an HDMI and a VGA audio/video source to the same HDMI display or projector, and automatically or manually switch between which video source is displayed. The multi-input A/V switch supports video resolution up to 1920x1200 (1080p) and includes mounting hardware for a tidy professional installation.
The A/V switch features built-in VGA conversion, enabling you to connect an HDMI and a VGA video source to the same HDMI display without the use of additional adapters or scalers. The switch also supports EDID pass-through, EDID copy, and EDID emulation to ensure your VGA and HDMI native resolutions will be maintained between both source connections.
The VS221VGA2HD ensures hassle-free operation with two different auto switching modes: automatic switching that detects and selects a newly connected device, as well as priority selection which lets you choose which port should be activated by default for automatic switching.
This A/V switch has been designed with the boardroom and classroom in mind: the VS221VGA2HD features VGA and HDMI inputs to support a wide range of devices, and the built-in converter makes it easy to connect to the room's display without the use of additional adapters. Plus, automatic switching encourages on-the-fly collaboration among students or co-workers, by making it easy to share your projector between multiple source devices.
If you are looking for a similar device with VGA output, please see the VS221HD2VGA.
StarTech.com 2x1 VGA + HDMI to HDMI Switch / Selector Box - 1080p Multi Video Input Automatic Switcher - 2 Computers In 1 Monitor Out (VS221VGA2HD) - video/audio switch
Video/audio switch
Subtype
HDMI
P/N: SVA5N3NEUA
Video/audio switch
Enclosure Type
Desktop
Subtype
HDMI
1 x VGA input HD-15 , 1 x HDMI input , 1 x HDMI output
External power adapter
Mounting brackets
FCC, RoHS
P/N: SVA5N3NEUA
B458 StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.91
B458 StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.00
B458 StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.48
B458 StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.78
B458 StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male In Stock £4.91
B458 StarTech.com 3m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £9.65
B458 StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £7.55
B458 StarTech.com 4-Port 4K HDMI Video Switch In Stock £115.03
B458 StarTech.com 2-Port 4K HDMI Video Switch In Stock £86.28
B458 StarTech.com 2x2 HDMI Matrix Switch - 4K In Stock £137.08
B458 StarTech.com DisplayPort VGA HDMI Converter Switch In Stock £150.51
B458 StarTech.com DC Power Adapter - 5V, 3A In Stock £12.25
