Connect your Computer or Audio Player to an RCA Audio Device. The MU3MMRCA 3-foot 3.5mm audio to RCA audio cable delivers a cost-effective solution for connecting a portable audio device such as an iPod (or other MP3 player) to a stereo receiver/amplifier.
This versatile cable can also be used to connect a computer sound card to an audio device that accepts RCA audio input.
The cable features a 3.5mm audio (male) connector, which splits off into two RCA (phono) audio male connectors, providing high quality stereo sound.
Designed to provide high quality audio as well as a durable and dependable connection.
Versatile connectivity
This audio cable features a 3.5 mm male connector on one end and dual RCA male connectors on the other, making it suitable for a range of audio devices. -
Color-coded connectors
The cable is equipped with color-coded connectors, simplifying the process of connecting audio equipment and reducing installation time. -
Durable construction
With a PVC jacket and 28 AWG design, this cable is built to withstand wear and tear while providing reliable audio quality. -
Safe and compliant
The product complies with RoHS standards, ensuring it is safe for both users and the environment.
 - StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male - heaDPhone jack to RCA - Mini jack to RCA - 3.5mm to RCA (MU3MMRCA) - audio cable - 92 cm
- Cable
 - Audio cable
- American Wire Gauge (AWG)
 - 28
- Length
 - 92 cm
 - Black
- Connector
 - Mini-phone stereo 3.5 mm - male
- Connector (Second End)
 - RCA x 2 - male
 - Colour-coded connectors
 - Limited lifetime warranty
- Designed For
 - P/N: DP2VGAA, DP2VGAAMM2M, DP2VGAAMM3M, HD202A, HD2A, HD2VGAA2, HD2VGAMICRA, IPUSB2VGA2, ST121HDBT5, ST121HDBTRP, ST121HDBTSC, ST121HDBTU, ST12MHDLAN4K, ST12MHDLAN4R, ST12MHDLNHK, ST12MHDLNHR, ST222HDBT, STDHVHDBT, VGA2HDPRO2, VID2HDCON2, VS221HD2VGA, VS221VGA2HD, WIFI2HD2, WIFI2HDMC, WIFI2HDVGA
- Cable Type
 - Audio cable
 - 28
- Jacket Material
 - PVC
- Length
 - 92 cm
 - Black
- Connector
 - RCA x 2 - male
 - RoHS
 - Limited warranty - lifetime
- Designed For
 - P/N: COMPUTPEXTA, CPNT2VGAA, CPNTA2HDMI, DP2VGAA, DP2VGAAMM2M, DP2VGAAMM3M, DVI2HDMIA, HD202A, HD2A, HD2VGAA2, HD2VGAMICRA, HDMI2VGA, IPUSB2VGA2, ST121HDBT5, ST121HDBTRP, ST121HDBTSC, ST121HDBTU, ST122DVIA, ST122HDMI2, ST122LEA, ST122PROA, ST123HDA, ST124DVIA, ST124HDMI2, ST124UTPEA, ST128HDMI2, ST12MHDLAN4K, ST12MHDLAN4R, ST12MHDLNHK, ST12MHDLNHR, ST222HDBT, ST222MXA, ST424MX, STDHVHDBT, STUTPEALR, STUTPWALLA, VGA2HD2, VGA2HDPRO2, VID2HDCON, VID2HDCON2, VS221HD2VGA, VS221VGA2HD, VS410RVGAA, VS420RDVIA, VS721MULTI, WIFI2HD2, WIFI2HDMC, WIFI2HDVGA
