StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg
Quicklinx: 887DWS00 Mfr#: CABSHELF22
Product Type: Rack shelf, Rack shelf
£35.56 ex VAT
£42.67 inc VAT
Add a sturdy, 22in depth fixed shelf into almost any server rack or cabinet. The CABSHELF22 2U 22in Depth Fixed Rack Mount Shelf lets you add a compact, 2U shelf to virtually any standard 19-inch server rack or cabinet with front mount options.
The high-quality rack shelves are designed to withstand harsh work environments with ease. Constructed using SPCC commercial grade cold-rolled steel, this durable fixed rack shelf can hold up to 22kg (50lbs) of equipment - a perfect solution for storing small, non-rackmount equipment, tools, peripherals or accessories in your rack to keep them readily accessible.
StarTech.com 2U Fixed Server Rack Mount Shelf - 22" Deep Steel Universal Cantilever Tray for 19" AV, Data, Network Equipment Rack - 50lbs (CABSHELF22) rack shelf - 2U
Rack shelf
Rack Size
22"
Height (Rack Units)
2U
Product Material
Cold-rolled steel
48.27 cm x 55.88 cm x 8.8 cm
4.1 kg
P/N: 2636CABINET, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1236BKF, RK12OD, RK2236BKF, RK2536BKF, RK4236BK, RK4242BK, RK960CP
Rack shelf
Product Material
Cold-rolled steel
Rack Size
22"
Height (Rack Units)
2U
48.27 cm
55.88 cm
8.8 cm
4.1 kg
Weight Limit
22.6 kg
Mounting Kit
Included
RoHS
Limited warranty - lifetime
887D StarTech.com 50 Pkg M5 Mounting Screws for Server Rack Cabinet In Stock £15.74
887D StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £14.19
887D StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £33.10
887D StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £26.81
887D StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £15.13
887D StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £29.15
887D StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.40
887D StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.51
887D StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg In Stock £22.09
887D StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg In Stock £62.63
887D StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg In Stock £80.11
887D StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg In Stock £35.56
887D StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg In Stock £39.08
887D StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £25.71
887D StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £44.04
Price Range Ex VAT: 0 - 50
