1U Vented Server Rack Cabinet Shelf, 20in Deep Fixed Cantilever Tray, Rackmount Shelf for 19" AV/Data/Network Equipment Enclosure w/ Cage Nuts & Screws, 55lbs Weight Capacity - 1U Network Rack Shelf (SHELF-1U-20-FIXED-V).
Sturdy Construction
The rack shelf is made of SPCC cold rolled steel which ensures durability and longevity even under heavy loads. -
Vented Design
The vented features of the shelf allow for enhanced airflow, helping to keep your equipment cool and functioning efficiently. -
Easy Installation
It comes with all necessary mounting hardware, including cage nuts and screws, facilitating a straightforward installation process. -
Compliance with Standards
This product meets EIA-310-E and ECA-310-E standards, ensuring compatibility with a range of rack and server equipment. -
Ample Space
With inner dimensions of 43.6 cm in width and 50.8 cm in depth, it provides sufficient space for various AV and network devices.
- StarTech.com 1U Vented Server Rack Cabinet Shelf, 20in Deep Fixed Cantilever Tray, Rackmount Shelf for 19" AV/Data/Network Equipment Enclosure w/ Cage Nuts & Screws, 55lbs Weight Capacity - 1U Network Rack Shelf - rack shelf - 1U
- Product Type
- Rack shelf
- Package Content
- 4 plastic washers, 4 M6 cage screws, 4 M6 square cage nuts
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 1U
- Product Material
- SPCC cold rolled steel
- 48.3 cm x 50.8 cm x 4.3 cm
- 3.5 kg
- Vented
- Limited lifetime warranty
- Product Type
- Rack shelf
- Product Material
- Package Content
- Rack Size
- 19"
- 1U
- 48.3 cm
- 50.8 cm
- 4.3 cm
- 3.5 kg
- Shipping Dimensions (WxDxH) / Weight
- 56 cm x 55 cm x 12 cm / 4.7 kg
- Inner Dimensions
- 43.6 cm x 50.8 cm
- Black
- Weight Limit
- 25 kg
- Vented
- EIA-310-E, ECA-310-E
- Limited warranty: - lifetime
StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £13.69 |
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £34.96 |
StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £30.08 |
StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £62.10 |
StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg | In Stock | £39.51 |
StarTech.com Vented 1U Rack Shelf - 16 in. | In Stock | £31.69 |
StarTech.com 1U Vented Shelf 12in | In Stock | £33.56 |
StarTech.com 2U Vented Shelf 14in | In Stock | £61.70 |
StarTech.com 2U Vented Shelf 20in | In Stock | £73.49 |
StarTech.com 2-Pack 1U Rack Shelf, Vented | In Stock | £68.84 |
