1U Vented Server Rack Cabinet Shelf, 12in Deep Fixed Cantilever Tray, Rackmount Shelf for 19" AV/Data/Network Equipment Enclosure w/ Cage Nuts & Screws, 55lbs Weight Capacity - 1U Network Rack Shelf (SHELF-1U-12-FIXED-V).
Robust construction
Crafted from SPCC cold rolled steel, this 1U vented server rack cabinet shelf offers a durable solution for mounting your AV, data, and network equipment securely within a 19" rack enclosure. Its sturdy build ensures long-term reliability and performance for your critical infrastructure. -
Efficient cooling
Featuring a vented design, this rackmount shelf promotes better air circulation around your equipment. This helps in maintaining optimal operating temperatures, reducing the risk of overheating and ensuring your systems run efficiently. -
Easy installation
Included with 4 M6 cage screws, 4 M6 square cage nuts, and 4 plastic washers, this 12 in deep fixed cantilever tray is designed for a hassle-free setup. Its compatibility with standard 19" AV, data, and network equipment enclosures makes it a versatile addition to any server room or data center.
- StarTech.com 1U Vented Server Rack Cabinet Shelf, 12in Deep Fixed Cantilever Tray, Rackmount Shelf for 19" AV/Data/Network Equipment Enclosure w/ Cage Nuts & Screws, 55lbs Weight Capacity - 1U Network Rack Shelf - rack shelf - 1U
- Product Type
- Rack shelf
- Package Content
- 4 plastic washers, 4 M6 cage screws, 4 M6 square cage nuts
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 1U
- Product Material
- SPCC cold rolled steel
- 48.3 cm x 30.5 cm x 4.3 cm
- 2.2 kg
- Vented
- Limited lifetime warranty
- Product Type
- Rack shelf
- Product Material
- Package Content
- Rack Size
- 19"
- 1U
- 48.3 cm
- 30.5 cm
- 4.3 cm
- 2.2 kg
- Shipping Dimensions (WxDxH) / Weight
- 37 cm x 55 cm x 12 cm / 3 kg
- Black
- Weight Limit
- 25 kg
- Vented
- EIA-310, ECA-310
- Limited warranty: - lifetime
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £30.66 |
StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £28.24 |
StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £54.39 |
StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg | In Stock | £37.00 |
StarTech.com Vented 1U Rack Shelf - 16 in. | In Stock | £31.83 |
StarTech.com 1U Vented Shelf 20in | In Stock | £56.28 |
StarTech.com 2U Vented Shelf 14in | In Stock | £62.75 |
StarTech.com 2-Pack 1U Rack Shelf, Vented | In Stock | £55.99 |
