Add a sturdy, 22in depth fixed shelf into almost any server rack or cabinet. The CABSHELF22 2U 22in Depth Fixed Rack Mount Shelf lets you add a compact, 2U shelf to virtually any standard 19-inch server rack or cabinet with front mount options.
The high-quality rack shelves are designed to withstand harsh work environments with ease. Constructed using SPCC commercial grade cold-rolled steel, this durable fixed rack shelf can hold up to 22kg (50lbs) of equipment - a perfect solution for storing small, non-rackmount equipment, tools, peripherals or accessories in your rack to keep them readily accessible.
- StarTech.com 2U Fixed Server Rack Mount Shelf, 22in Deep Steel Universal Cantilever Tray for 19" AV/Data/Network Equipment Rack with Cage Nuts & Screws, 50lbs Weight Capacity, 22" Deep - 2U Network Rack Shelf (CABSHELF22) - rack shelf - 2U
- Product Type
- Rack shelf
- Black
- Rack Size
- 22"
- Height (Rack Units)
- 2U
- Product Material
- Cold-rolled steel
- 48.27 cm x 55.88 cm x 8.8 cm
- 4.1 kg
- Limited lifetime warranty
- Designed For
- P/N: 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKHD, RK1233BKM, RK1236BKF, RK12OD, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BKB, RK4242BK24, RK4242BK30, RK8OD, RK960CP
- Product Type
- Rack shelf
- Product Material
- Cold-rolled steel
- Rack Size
- 22"
- 2U
- 48.27 cm
- 55.88 cm
- 8.8 cm
- 4.1 kg
- Black
- Weight Limit
- 22.6 kg
- Mounting Kit
- Included
- RoHS
- Limited warranty: - lifetime
- Designed For
- P/N: 2636CABINET, 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1233BKM, RK1236BKF, RK12OD, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK8OD, RK960CP
StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £13.28 |
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £33.14 |
StarTech.com Black Standard Universal Server Rack Cabinet Shelf | In Stock | £33.34 |
StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet | In Stock | £15.71 |
StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £31.71 |
StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £60.18 |
StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £63.56 |
StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg | In Stock | £22.78 |
StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg | In Stock | £89.58 |
StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg | In Stock | £48.80 |
StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg | In Stock | £43.24 |
StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg | In Stock | £32.89 |
StarTech.com Vented 1U Rack Shelf - 7in | In Stock | £23.04 |
StarTech.com Vented 1U Rack Shelf - 16 in. | In Stock | £35.50 |
StarTech.com Vented 1U Rack Shelf - 10in | In Stock | £23.40 |
StarTech.com 1U Server Rack Shelf - 16in. Deep - EIA/ECA-310 Compliant | In Stock | £37.59 |
StarTech.com 1U Vented Shelf 12in | In Stock | £40.14 |
StarTech.com 1U Vented Shelf 20in | In Stock | £62.85 |
StarTech.com 2U Vented Shelf 14in | In Stock | £60.75 |
StarTech.com 2U Vented Shelf 20in | In Stock | £75.95 |
