Brand
StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg
Quicklinx: 887DWS00 Mfr#: CABSHELF22
Product Type: Rack shelf, Rack shelf
£47.74 ex VAT
£57.28 inc VAT
Add a sturdy, 22in depth fixed shelf into almost any server rack or cabinet. The CABSHELF22 2U 22in Depth Fixed Rack Mount Shelf lets you add a compact, 2U shelf to virtually any standard 19-inch server rack or cabinet with front mount options.
The high-quality rack shelves are designed to withstand harsh work environments with ease. Constructed using SPCC commercial grade cold-rolled steel, this durable fixed rack shelf can hold up to 22kg (50lbs) of equipment - a perfect solution for storing small, non-rackmount equipment, tools, peripherals or accessories in your rack to keep them readily accessible.
StarTech.com 2U Fixed Server Rack Mount Shelf, 22in Deep Steel Universal Cantilever Tray for 19" AV/Data/Network Equipment Rack with Cage Nuts & Screws, 50lbs Weight Capacity, 22" Deep - 2U Network Rack Shelf (CABSHELF22) - rack shelf - 2U
Rack shelf
Rack Size
22"
Height (Rack Units)
2U
Product Material
Cold-rolled steel
48.27 cm x 55.88 cm x 8.8 cm
4.1 kg
P/N: 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKHD, RK1233BKM, RK1236BKF, RK12OD, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BKB, RK4242BK24, RK4242BK30, RK8OD, RK960CP
Rack shelf
Product Material
Cold-rolled steel
Rack Size
22"
Height (Rack Units)
2U
48.27 cm
55.88 cm
8.8 cm
4.1 kg
Weight Limit
22.6 kg
Mounting Kit
Included
RoHS
Limited warranty: - lifetime
P/N: 2636CABINET, 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1233BKM, RK1236BKF, RK12OD, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK8OD, RK960CP
887D StarTech.com 50 Pkg M5 Mounting Screws for Server Rack Cabinet In Stock £18.83
887D StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £13.28
887D StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £33.88
887D StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £33.34
887D StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £15.71
887D StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £31.71
887D StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £60.18
887D StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £63.56
887D StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg In Stock £25.54
887D StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg In Stock £43.24
887D StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £33.61
887D StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £48.75
887D StarTech.com Vented 1U Rack Shelf - 7in In Stock £23.04
887D StarTech.com Vented 1U Rack Shelf - 16 in. In Stock £36.26
887D StarTech.com Vented 1U Rack Shelf - 10in In Stock £23.89
887D StarTech.com 1U Server Rack Shelf - 16in. Deep - EIA/ECA-310 Compliant In Stock £37.59
887D StarTech.com 1U Vented Shelf 12in In Stock £40.14
887D StarTech.com 1U Vented Shelf 20in In Stock £62.85
887D StarTech.com 2U Vented Shelf 14in In Stock £60.75
887D StarTech.com 2U Vented Shelf 20in In Stock £75.95
