Add a sturdy, 22in depth fixed shelf into almost any server rack or cabinet. The CABSHELF22 2U 22in Depth Fixed Rack Mount Shelf lets you add a compact, 2U shelf to virtually any standard 19-inch server rack or cabinet with front mount options.
The high-quality rack shelves are designed to withstand harsh work environments with ease. Constructed using SPCC commercial grade cold-rolled steel, this durable fixed rack shelf can hold up to 22kg (50lbs) of equipment - a perfect solution for storing small, non-rackmount equipment, tools, peripherals or accessories in your rack to keep them readily accessible.
Sturdy Material
Crafted from cold-rolled steel, this rack shelf offers strength and durability, ensuring long-lasting use and reliable support for various equipment. -
Easy Installation
The included mounting kit allows for straightforward installation, enabling users to set up their server rack efficiently. -
Environmentally Compliant
With compliance to RoHS standards, this product reflects a commitment to environmentally friendly manufacturing, ensuring a reduced impact on health and the environment. -
Ample Weight Capacity
Able to support loads up to 22.6 kg, this shelf provides strength for housing a variety of equipment, enhancing overall functionality. -
Versatile Sizing
Designed for a 22-inch rack size, this shelf fits seamlessly into standard server racks, making it a versatile addition to IT setups.
- StarTech.com 2U Fixed Server Rack Mount Shelf, 22in Deep Steel Universal Cantilever Tray for 19" AV/Data/Network Equipment Rack with Cage Nuts & Screws, 50lbs Weight Capacity, 22" Deep - 2U Network Rack Shelf (CABSHELF22) - rack shelf - 2U
- Product Type
- Rack shelf
- Black
- Rack Size
- 22"
- Height (Rack Units)
- 2U
- Product Material
- Cold-rolled steel
- 48.27 cm x 55.88 cm x 8.8 cm
- 4.1 kg
- Limited lifetime warranty
- Designed For
- P/N: 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKHD, RK1233BKM, RK1236BKF, RK12OD, RK12OD2, RK1833BKM, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BKB, RK4242BK24, RK4242BK30, RK8OD, RK960CP
- Product Type
- Rack shelf
- Product Material
- Cold-rolled steel
- Rack Size
- 22"
- 2U
- 48.27 cm
- 55.88 cm
- 8.8 cm
- 4.1 kg
- Black
- Weight Limit
- 22.6 kg
- Mounting Kit
- Included
- RoHS
- Limited warranty: - lifetime
- Designed For
- P/N: 2636CABINET, 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1233BKM, RK1236BKF, RK12OD, RK12OD2, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK8OD, RK960CP
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £30.66 |
StarTech.com Black Standard Universal Server Rack Cabinet Shelf | In Stock | £30.71 |
StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £28.24 |
StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £54.39 |
StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £57.53 |
StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg | In Stock | £25.30 |
StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg | In Stock | £74.28 |
StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg | In Stock | £81.75 |
StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg | In Stock | £56.70 |
StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg | In Stock | £44.28 |
StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg | In Stock | £37.00 |
StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg | In Stock | £51.38 |
StarTech.com Vented 1U Rack Shelf - 7in | In Stock | £24.38 |
StarTech.com 1U Rack Shelf - 10in | In Stock | £25.16 |
StarTech.com Vented 1U Rack Shelf - 16 in. | In Stock | £31.83 |
StarTech.com Vented 1U Rack Shelf - 10in | In Stock | £21.05 |
StarTech.com 1U Server Rack Shelf - 16in. Deep - EIA/ECA-310 Compliant | In Stock | £39.75 |
StarTech.com 1U Vented Shelf 12in | In Stock | £34.44 |
StarTech.com 1U Vented Shelf 20in | In Stock | £56.28 |
StarTech.com 2U Vented Shelf 14in | In Stock | £62.75 |
StarTech.com 2-Pack 1U Rack Shelf, Vented | In Stock | £55.99 |
