StarTech.com 2PT Serial-to-IP Device Server
Quicklinx: C53FWS00 Mfr#: NETRS2322P
Hurry, only 1 left in stock!
£162.85 ex VAT
£195.42 inc VAT
Connect, configure and manage two remote RS232 serial devices, over an IP network. This 2-port serial device server is a cost-effective way to remotely connect to and manage two serial devices over your typical IP network. The device server integrates two RS232 ports into a rugged metal housing with an extended operating temperature range, so it's perfect for factory and industrial settings.
If you're looking for a reliable serial-over-IP control solution, then this device server can help. With a rugged metal housing and an extended operating temperature range, you can rest assured that the device server can deliver the reliable performance you need, even in harsh environments.
Plus, it features two integrated mounting brackets, so you can mount the device server to a surface or a wall as needed, for out-of-the-way installations.
With redundant power input, this dual-port serial device server ensures seamless operation, even in the event of power dips or failures. It features a wide-range, terminal block power input (9~36V DC), and includes a universal power adapter.
Because it features two power inputs, if you experience a power disruption the device server automatically switches to its secondary power source. With redundant power input, the device server remains operational if one of the power sources fails, so you can continue to connect to and manage your serial devices when needed.
This highly customizable device server is easy to configure to suit your application. For easy setup, Windows users can use the provided Virtual COM port software, or the versatile Web-based interface.
The RS232 device server supports Telnet (an operating system independent communication protocol), so it can be integrated into mixed OS environments (Windows, Mac, Linux). Plus, it supports VCOM, TCP, ICMP, IP, TCP, UDP, DHCP, and BOOTP protocols.
StarTech.com 2 Port Serial-to-IP Ethernet Device Server - RS232 - Metal and Mountable - Serial Device Server - RS232 Serial-Over-IP (NETRS2322P) - device server
Device server
In-wall mountable
Australia, North America, United Kingdom, Europe
Ports Qty
2
Ethernet, Fast Ethernet, RS-232
Power terminal block
Apple MacOS, Linux, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Microsoft Windows Server 2019
AC 120/230 V / DC 9 - 36 V
Power Redundancy
8 cm x 11.3 cm x 2.5 cm
310 g
Device server
8 cm
11.3 cm
2.5 cm
310 g
Enclosure Colour
In-wall mountable
Ports Qty
2
Wired
Data Transfer Rate
460.8 Kbps
Network / Transport Protocol
TCP/IP, UDP/IP, ICMP/IP, BOOTP, DHCP
Remote Management Protocol
Telnet
Status Indicators
Status, LAN, link/activity
Full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), 15 KV Electrostatic Discharge Protection, reset button, 8 KV Contact Electrostatic Discharge Protection
IEEE 802.3, IEEE 802.3u
2 x RS-232 - DB-9 , 1 x 100Base-TX - RJ-45
FCC, RoHS, WEEE, RCM
External power adapter
Power Redundancy
Software Included
Drivers & Utilities, Virtual COM software (Windows only)
85 °C
C53F StarTech.com Slimline DB9 Serial Gender Changer - F/F In Stock £4.64
C53F StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £5.58
C53F StarTech.com 5 Ports Industrial Ethernet Switch In Stock £67.24
C53F StarTech.com Serial to Ethernet Adapter In Stock £120.64
C53F StarTech.com PoE Serial to Ethernet Adapter In Stock £160.87
C53F StarTech.com 2P Serial to Ethernet Adapter In Stock £185.00
C53F StarTech.com 4P Serial to Ethernet Adapter In Stock £321.80
Type: Device Server
