The StarTech.com 4P Serial to Ethernet Adapter is designed to integrate your RS232 devices into modern TCP/IP networked environments. This adapter combines the reliability of RS-232 serial connections with the speed and scalability of 100Base-TX Ethernet, making it a suitable choice for industries requiring robust and versatile communication solutions. With its durable metal housing and advanced protection against electrostatic discharge up to 15 KV, it ensures operational reliability in industrial settings. The device supports efficient data management with features like auto-negotiation, flow control, and full duplex capability, facilitating smooth and reliable data transfer rates of up to 921.6 Kbps. Installation flexibility is provided through wall or DIN rail mounting options, catering to various operational setups. Additionally, the adapter's capability for static IP routing and support for remote management protocols such as Telnet and UDP make it a secure and manageable choice for integrating legacy serial devices into a modern network infrastructure.
Robust connectivity
Equipped with both RS-232 and 100Base-TX interfaces, this adapter ensures versatile connectivity options for a wide range of devices. -
Enhanced durability
The metal housing and electrostatic discharge protection up to 15 KV provide a durable solution for demanding industrial environments. -
Efficient management
Features such as auto-negotiation, flow control, and full duplex capability ensure efficient data management and transfer rates up to 921.6 Kbps. -
Flexible installation
With options for wall or DIN rail mounting, this device server can be installed in various settings, making it a versatile choice for network infrastructure. -
Secure operation
Support for static IP routing and remote management protocols like Telnet and UDP allows for secure and manageable network configurations.
- StarTech.com 4P Serial to Ethernet Adapter, IP LAN to RS232 DB9 Converter - device server - TAA Compliant
- Device server
- Form Factor
- Wall / DIN rail mountable
- Ports Qty
- 4
- Data Link Protocol
- Ethernet, Fast Ethernet, RS-232
- Included Accessories
- DIN-rail mounting kit, wall mounting kit
- OS Required
- Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11
- Power
- AC 100-240 V
- TAA Compliant
- 6 cm x 17.9 cm x 2.3 cm
- 400 g
- 2-year warranty
- Designed For
- P/N: AT925FM, GC9SF, SCNM9FF, SCNM9FM
- Device server
- 6 cm
- 17.9 cm
- 2.3 cm
- 400 g
- Enclosure Colour
- Black
- Form Factor
- Ports Qty
- 4
- Connectivity Technology
- Wired
- Data Transfer Rate
- 921.6 Kbps
- Telnet, UDP, TCP
- Routing Protocol
- Static IP routing
- Remote Management Protocol
- Telnet, UDP
- Status Indicators
- Power, transmit, receive, link/activity
- Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), manageable, 15 KV Electrostatic Discharge Protection, metal housing, 8 KV Contact Electrostatic Discharge Protection, adjustable parity
- IEEE 802.3u, IEEE 802.3i
- 4 x RS-232 - DB-9 , 1 x 100Base-TX - RJ-45 , 1 x - terminal block
- EIA/TIA-232
- TAA Compliant
- Power Device
- External power adapter
- Voltage Required
- AC 100-240 V
- 15 Watt
- OS Required
- Shipping Width
- 16.6 cm
- Shipping Depth
- 24.2 cm
- Shipping Height
- 5.5 cm
- Shipping Weight
- 600 g
- Limited warranty - 2 years
- 0 °C
- 60 °C
- 5 - 95% RH (non-condensing)
- Designed For
StarTech.com Slimline DB9 Serial Gender Changer - F/F | In Stock | £4.74 |
StarTech.com DB9 to DB25 Serial Cable Adapter - F/M | In Stock | £5.40 |
StarTech.com Serial to Ethernet Adapter | In Stock | £114.44 |
StarTech.com PoE Serial to Ethernet Adapter | In Stock | £152.62 |
StarTech.com 2P Serial to Ethernet Adapter | In Stock | £175.53 |
