StarTech.com PoE Serial to Ethernet Adapter
Quicklinx: HVMDWS00 Mfr#: I13P-SERIAL-ETHERNET
10 In Stock
£156.44 ex VAT
£187.72 inc VAT
The StarTech.com Serial to Ethernet Adapter is a versatile connectivity solution designed to bridge the gap between RS232 DB9 devices and IP-based networks. With its robust metal housing and advanced electrostatic discharge protection, it offers reliability and durability in various operational environments, from industrial settings to office spaces. The adapter supports Power over Ethernet (PoE), allowing for a cleaner setup with fewer cables and no need for external power supplies. It features a comprehensive suite of network functionalities including auto-negotiation, full duplex capability, and static IP routing, ensuring efficient and manageable network integration. Furthermore, the device is equipped with remote management capabilities, enabling secure and straightforward configuration and monitoring over the network. Whether it's for connecting surveillance cameras, point of sale systems, or industrial equipment, the StarTech.com Serial to Ethernet Adapter provides a reliable, efficient, and secure way to extend your network connectivity.
  • Robust connectivity
    Equipped with both RS-232 and 100Base-TX (PoE) interfaces, this Serial to Ethernet Adapter ensures versatile connectivity options for a wide range of devices, making it an ideal solution for diverse operational environments.
  • Enhanced durability
    The metal housing and electrostatic discharge protection up to 15 kV provide a durable solution that can withstand harsh industrial environments, ensuring reliable performance and longevity.
  • Efficient power management
    With Power over Ethernet (PoE) capability, this adapter simplifies installation by eliminating the need for a separate power supply, offering a streamlined setup and reducing clutter.
  • Advanced network features
    Features such as auto-negotiation, full duplex capability, and static IP routing support efficient network communication and management, enhancing the adapter's performance in complex network infrastructures.
  • Secure remote management
    Support for Telnet and UDP remote management protocols allows for secure and convenient configuration and monitoring of the adapter, facilitating efficient management of networked devices.
StarTech.com Serial to Ethernet Adapter, IP LAN to RS232 DB9 Converter - device server - PoE - TAA Compliant
Device server
Wall / DIN rail mountable
Ethernet, Fast Ethernet, RS-232
Wall mounting kit, DIN-rail mounting kit
Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11
Power Over Ethernet (PoE) Supported
PoE
TAA Compliant
8.2 cm x 4.6 cm x 2.5 cm
155 g
Device server
8.2 cm
4.6 cm
2.5 cm
155 g
Enclosure Colour
Wired
Data Transfer Rate
921.6 Kbps
Network / Transport Protocol
Telnet, TCP, UDP
Routing Protocol
Static IP routing
Remote Management Protocol
Telnet, UDP
Status Indicators
Link/activity, power, transmit, receive, PoE
Metal housing, 15 KV Electrostatic Discharge Protection, 8 KV Contact Electrostatic Discharge Protection, auto-negotiation, flow control, adjustable parity, manageable, auto-uplink (auto MDI/MDI-X), full duplex capability
IEEE 802.3af, IEEE 802.3u, IEEE 802.3i
1 x RS-232 - DB-9 , 1 x 100Base-TX (PoE) - RJ-45 - 15.4 W
EIA/TIA-232
TAA Compliant
PoE
External power adapter
Shipping Width
20.7 cm
Shipping Depth
14.4 cm
Shipping Height
3 cm
Shipping Weight
1.2 kg
60 °C
5 - 95% RH (non-condensing)
HVMD StarTech.com Slimline DB9 Serial Gender Changer - F/F In Stock £4.77
HVMD StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £5.43
HVMD StarTech.com Serial to Ethernet Adapter In Stock £117.30
HVMD StarTech.com 2P Serial to Ethernet Adapter In Stock £179.91
HVMD StarTech.com 4P Serial to Ethernet Adapter In Stock £312.93
