StarTech.com 2m USB 2.0 A to A Cable - M/M
Quicklinx: 7W8VWS00 Mfr#: USB2AA2M
Length: 2m
12 In Stock
£5.05 ex VAT
£6.06 inc VAT
Connect USB 2.0 devices to a USB hub or to your computer. The USB2AA2M 2-meter USB 2.0 cable features two USB A male connectors, delivering a dependable way to connect your PC to a USB hub, or connect USB 2.0 peripherals to a USB hub.
  • Dependable connectivity
    This cable features male to male USB Type-A connectors, ensuring a secure connection between devices that require direct linking.
  • Flexible length
    With a length of 2 m, this cable allows for versatile placement of devices, accommodating various setups without being restrictive.
  • Efficient data transfer
    Compliant with USB 2.0 standards, this cable provides reliable data transfer rates, making it suitable for everyday applications.
  • Durable design
    Constructed with American Wire Gauge of 24/28, this cable is built for durability and consistent performance.
  • Environmentally conscious
    This product is RoHS compliant, ensuring that it meets standards for reducing hazardous substances in electronics.
StarTech.com 2m USB 2.0 A to A Cable - M/M - 2m USB 2.0 aa Cable - USB a male to a male Cable (USB2AA2M) - USB cable - USB to USB - 2 m
USB cable
Length
2 m
Connector
4 pin USB Type A - male
Connector (Second End)
USB / USB 2.0
P/N: SV231HDMIUA
USB cable
American Wire Gauge (AWG)
24/28
Length
2 m
Connector
USB / USB 2.0, RoHS
P/N: SV231HDMIUA
7W8V StarTech.com 1m USB 2.0 A to A Cable - M/M In Stock £4.90
7W8V StarTech.com 2m USB 2.0 A to A Cable - M/M In Stock £5.05
Length: 2m
