Connect USB 2.0 devices to a USB hub or to your computer. The USB2AA2M 2-meter USB 2.0 cable features two USB A male connectors, delivering a dependable way to connect your PC to a USB hub, or connect USB 2.0 peripherals to a USB hub.
Dependable connectivity
This cable features male to male USB Type-A connectors, ensuring a secure connection between devices that require direct linking. -
Flexible length
With a length of 2 m, this cable allows for versatile placement of devices, accommodating various setups without being restrictive. -
Efficient data transfer
Compliant with USB 2.0 standards, this cable provides reliable data transfer rates, making it suitable for everyday applications. -
Durable design
Constructed with American Wire Gauge of 24/28, this cable is built for durability and consistent performance. -
Environmentally conscious
This product is RoHS compliant, ensuring that it meets standards for reducing hazardous substances in electronics.
- StarTech.com 2m USB 2.0 A to A Cable - M/M - 2m USB 2.0 aa Cable - USB a male to a male Cable (USB2AA2M) - USB cable - USB to USB - 2 m
- USB cable
- Length
- 2 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- USB / USB 2.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: SV231HDMIUA
- USB cable
- American Wire Gauge (AWG)
- 24/28
- Length
- 2 m
- Black
- Connector
- USB / USB 2.0, RoHS
- Designed For
- P/N: SV231HDMIUA
StarTech.com 1m USB 2.0 A to A Cable - M/M | In Stock | £5.19 |
StarTech.com 2m USB 2.0 A to A Cable - M/M | In Stock | £5.27 |
