StarTech.com 2m HDMI Extension Cable - Ultra HD 4k x 2k HDMI Cable - M/F
Quicklinx: 8659WS00 Mfr#: HDEXT2M
Extend the connection distance between your HDMI-enabled devices by 2 meters. The HDEXT2M HDMI extension cable (2m) features an HDMI 19-pin (male) connector on one end and an HDMI 19-pin (female) connector on the other, providing an extra 2-meter connection distance between your HDMI-enabled devices.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
StarTech.com High Speed HDMI extension cables are expertly designed and constructed of only top quality materials to ensure high quality, high-definition performance. The HDMI standard combines high bandwidth video and multi-channel digital audio into a single cable, and provides crystal clear image resolution.
StarTech.com 2m (6ft) HDMI Extension Cable, Ultra HD HDMI Male to Female Cable, 4K HDMI Cable Extender, 4K 30Hz UHD HDMI Cable with Ethernet M/F, High Speed HDMI 1.4 Cable, 10.2Gbps - HDMI Cord Extender - HDMI extension cable - 2 m
Cable
Shielded
American Wire Gauge (AWG)
28
Length
2 m
Connector
HDMI - male
Connector (Second End)
HDMI - female
P/N: CDP2HDMM2MB, DP2HDMM2MB, HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6, HDMM10, HDMM12, HDMM15, HDMM1MP, HDMM25, HDMM2M, HDMM2MP, HDMM3, HDMM3MP, HDMM50, HDMM50A, HDMM6, HDPMM50, MDP2HDMM2MB
Cable Type
Shielded
28
Jacket Material
PVC
Shielding Material
Length
2 m
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
19 pin HDMI Type A - female
Limited warranty - lifetime
