StarTech.com StarTech.com 1m Premium HDMI 2.0 Cable w/Ethernet - 3ft HDR
Quicklinx: FTWSWS00 Mfr#: RHDMM1MPW
£12.00 ex VAT
£14.40 inc VAT
HIGH PERFORMANCE CABLE: 3.3 ft (1 m) Premium Certified HDMI 2.0 with Ethernet, 4K 60Hz (up to 4096x2160p), 18Gbps bandwidth, HDR10 for high contrast ratio, Ultra wide aspect ratio, 32 Ch multi-stream audio (5.1/7.1/DD+/Dolby TrueHD/Atmos) 1536Hz sampling.
DURABLE: HDMI cable w/Kevlar aramid fiber for high tensile strength & durability; Tested up to 10000+ bend cycles at 180° angle & 5000+ insertions; Al-Mylar Foil w/ Braid provides EMI shielding ensures signal integrity; Ideal for Commercial environments.
FLEXIBLE CABLE: Long lasting TPE jacket and strain relief absorbs stress of frequent bends protecting the core of the rugged UHD HDMI 34AWG cord; TPE is non-toxic, halogen free and RoHS certified for environmental sustainability.
APPLICATIONS: Ideal for home/office and travel, works with computer/laptop/desktop/workstation; Connect your TV/monitor/display/projector/soundbar; Samsung/Sony/Apple TV/Dell/LG; Compatible with HDMI 2.0 Ultra HD, 1080p Full HD and previous HDMI versions SPECS: 1 m (3.3 ft) | Black | HDMI 2.0 | HDMI Male to Male | 34 AWG | Reinforcement: Aramid Fiber | Jacket: TPE | EMI Shielding | Audio Return Channel (ARC), HDCP 2.2, CEC, BT.2020 colorimetry.
  • Built for Daily Use
    This Premium Certified HDMI cable has aramid fiber reinforcement that?braces?it from the stress of frequent bends. This also lets the cable flex without?over-stretching?or damaging?the core of the cord.
  • Flexible Strain Relief
    The cable is constructed to prevent the connector from separating from the jacket. The extra-long strain relief molding is tested to withstand over 10,000+ bend cycles at a 180° angle.
  • Connector Key Features • HDMI gold plated connector with metal shield protects the circuit board from EMI and reinforces the connection point • Strain relief tested to tolerate over 10,000+ bend cycles at a 180° angle
    Supporting all HDMI 2.0 specifications, this 3ft white HDMI Premium Certified cable?supports?resolutions up to 4k 60Hz with a bandwidth of up to 18Gbps. The short male to male HDMI cable also supports HDR for higher contrast ratio and vivid colors providing?an?enriched?and enjoyable?viewing experience. RHDMM1MPW is backed by a StarTech.com lifetime warranty and free lifetime technical support. Note: DuPont and Kevlar are trademarks or registered trademarks of E.I. du Pont de Nemours and Company.
Startech HDMI cable with Ethernet - 1 m
Cable
Premium High Speed - HDMI cable with Ethernet
American Wire Gauge (AWG)
30
Cable Length
1 m
White
Connector
HDMI - male
Connector (Second End)
HDMI - male
4K format support, HDR support, EMI/RFI protection
P/N: TB3DKM2HDL
Cable Type
30
Jacket Material
PVC
Shielding Material
Cable Length
1 m
Plated Connector
Gold
White
Connector
19 pin HDMI Type A - male
Shipping Width
18.2 cm
Shipping Depth
15 cm
Shipping Height
2 cm
Shipping Weight
78 g
P/N: TB3DKM2HDL
