HIGH PERFORMANCE 8K CABLE:
20in (50cm) Ultra HD HDMI 2.1 cable - 8K/5K 60Hz, 4K 120Hz (48Gbps) - Dynamic HDR10+ and Dolby Vision for high contrast and vivid picture - eARC, DTS-HD Master Audio/DTS:X/Dolby TrueHD/Atmos for high quality audio - HDCP 2.3
CERTIFIED CABLE:
Ultra High Speed HDMI 2.1 Certification ensures each cable delivers full 8K performance - Encased in die-cast aluminum shielding to improve signal integrity and prevent signal degradation due to EMI Interference
DURABLE:
UHD HDMI cord is tested to withstand 10,000+ insertions & 600+ bend cycles at 120° - Corrosion-resistant gold-plated connectors - Long lasting flexible TPE jacket and strain reliefs - TPE is non-toxic and halogen free
APPLICATIONS:
8K HDMI cable is ideal for Commercial, AV Production and High-Res applications - For home, office, classroom - Works with computer, laptop, desktop, or workstations to connect TV/monitor/display/projector - Samsung/Sony/Apple TV/Dell/LG
SPECS:
20 inch (50 cm) - HDMI 2.1 - Certified Ultra High Speed HDMI Cable 48Gbps - HDMI Male to Male - 8 mm (0.31") Outer Diameter and 26AWG - TPE Jacket - Al-Mylar Foil w/Braid EMI Shielding - Works with HDMI 2.0b/2.0a/2.0/1.4
Experience HDMI
This high performance 8K cable supports resolutions of up to 8K at 60 Hz (7680 x 4620p), 5K at 60 Hz, and 4K at 120 Hz at bandwidths of up to 48 Gbps. It supports High Dynamic Range (HDR10+) and Dolby Vision for higher contrast ratio and vivid colors. In addition, eARC (Enhanced Audio Return Channel) supports up to 32 uncompressed 5.1 and 7.1 digital audio channels to support DTS-HD Master Audio, DTS:X, Dolby TrueHD, Dolby Atmos for high quality sound. HDCP 2.3 encrypts and secures your video and audio content. The perfect cable for creating the ultimate home theater or for providing lifelike digital signage. This cable is compatible with all 8K ready devices and is backward compatible with previous HDMI specifications. -
Ultra-high speed certification
The cable has undergone rigorous compliance testing and is certified by an HDMI Authorized Test Center. This ensures it supports the high bandwidth enabled features it promises. An EMI test is performed to ensure the cable minimizes interference from wireless signals.
- Startech 20in (50cm) HDMI 2.1 Cable 8K - Certified Ultra High Speed HDMI Cable 48Gbps - 8K 60Hz/4K 120Hz HDR10+ eARC - Ultra HD 8K HDMI Cord - Monitor/TV/Display - Flexible TPE Jacket - HDMI cable - 50 cm
- Cable
- Ultra High Speed - HDMI cable
- Technology
- Shielded
- American Wire Gauge (AWG)
- 30/32
- Cable Length
- 50 cm
- Grey, black
- Connector
- HDMI - male
- Connector (Second End)
- HDMI - male
- Passive adapter, 4K120Hz support, 8K60Hz (7680 x 4320) support
- Limited lifetime warranty
- Cable Type
- Ultra High Speed - HDMI cable passive, 4K120Hz support, 8K60Hz (7680 x 4320) support
- Technology
- Shielded
- 30/32
- Jacket Material
- Thermoplastic elastomer (TPE)
- Shielding Material
- Aluminum mylar foil with braid
- Cable Length
- 50 cm
- Plated Connector
- Gold
- Dolby TrueHD support, Dolby DTS-HD Master Audio support, Dolby Atmos support, Enhanced Audio Return Channel (eARC), Dolby DTS:X support, Dolby Vision, 48Gbps support, support HDR10+, corrosion-resistant connectors, strain relief, 32 audio channels, outer diameter 6mm
- Grey, black
- Connector
- 19 pin HDMI Type A - male
- RoHS, WEEE, HDCP 2.3
- 288 g
- Shipping Width
- 22 cm
- Shipping Depth
- 20 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 290 g
- Limited warranty - lifetime
StarTech.com 12ft Ultra High Speed HDMI 2.1 | In Stock | £33.33 |
