Create high-resolution 4k x 2k connections with HBR2 support between your DisplayPort-equipped devices. The DISPL2M 2m DisplayPort 1.2 Cable with latches provides a secure, connection between your DisplayPort-equipped devices and is capable of providing higher performance than either HDMI or dual link DVI.
The DP cable supports high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz with a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
Durable construction
This cable features aluminum mylar foil with braid shielding, providing a strong and reliable connection. -
Secure connection
The latched design of the connectors ensures they remain firmly attached, reducing the risk of disconnection. -
High-resolution support
Capable of delivering resolutions up to 4K, this cable is perfect for users who require high-quality video output for gaming, presentations, or professional applications.
- StarTech.com 2m Certified DisplayPort 1.2 Cable M/M with Latches DP 4k - DisplayPort cable - 2 m
- DisplayPort cable
- Technology
- Shielded
- Latched
- Length
- 2 m
- Connector
- DisplayPort - male
- Connector (Second End)
- RoHS
- Black
- Limited lifetime warranty
- DisplayPort cable
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Latched
- Length
- 2 m
- Black
- Connector
- 20 pin DisplayPort - male
- RoHS
StarTech.com 3ft DisplayPort Panel Mount Cable - F/M | In Stock | £14.07 |
StarTech.com 5m Long DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £26.25 |
StarTech.com 2m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £12.37 |
StarTech.com 1m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £10.20 |
StarTech.com 3m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £22.80 |
StarTech.com 7m DisplayPort Cable with Latches - M/M | In Stock | £60.26 |
