StarTech.com 7m DisplayPort Cable with Latches - M/M
Quicklinx: 9FSRWS00 Mfr#: DISPL7M
Length: 7m
11 In Stock
£11.82 ex VAT
£14.18 inc VAT
Connect DisplayPort-equipped devices over longer distances. The DISPL7M DisplayPort Cable with latches provides a secure connection between your DisplayPort-enabled devices and allows for a connection distance of up to 7 meters between your source and display.
With a bandwidth of 10.8Gbps and support for maximum resolutions up to 2560x1600 (WQXGA), as well as optional audio support, this 7-meter DisplayPort cable offers impressive video capability and ensures that digitally protected content is displayed properly, with both HDCP and DPCP capability.
  • Durable construction
    The cable is made with shielding material consisting of aluminum mylar foil with braid, ensuring durability and effective signal integrity.
  • Secure latching mechanism
    The latched connectors prevent accidental disconnections and ensure a stable connection even in busy environments.
  • Optimized for performance
    With a 28 AWG rating, this DisplayPort cable supports high-speed data transfer, making it suitable for high-definition video and audio.
  • Corrosion-resistant connectors
    Nickel-plated connectors provide resistance to wear and tear while ensuring optimal conductivity and performance.
  • Environmentally compliant
    This cable meets RoHS standards, reflecting a commitment to using materials that are safer for the environment.
StarTech.com 7m DisplayPort Cable with Latches M/M - DisplayPort cable - 7 m
DisplayPort cable
Shielded
Latched
Length
7 m
Connector
DisplayPort - male
Connector (Second End)
DisplayPort - male
RoHS
DisplayPort cable
Shielded
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Latched
Length
7 m
Connector
20 pin DisplayPort - male
RoHS
9FSR StarTech.com 5m Long DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £16.94
9FSR StarTech.com 2m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £9.57
9FSR StarTech.com 1m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £5.83
9FSR StarTech.com 3m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £15.35
Length: 7m
