Create high-resolution 4k x 2k connections with HBR2 support between your DisplayPort-equipped devices. The DISPL3M 3m DisplayPort 1.2 Cable with latches provides a secure, connection between your DisplayPort-equipped devices and is capable of providing higher performance than either HDMI or dual link DVI.
The DP cable supports high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz with a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
Secure Connection
The latched connectors ensure that the DisplayPort cable remains securely plugged in, preventing accidental disconnections. -
High-Resolution Support
This cable supports up to 4K resolution, allowing for stunning visuals in any multimedia setup. -
Durable Construction
Made with aluminum mylar foil and braid shielding, this cable is designed to withstand everyday use while providing excellent video quality. -
Reduced Interference
The shielded design minimizes signal interference, ensuring a stable and uninterrupted connection for high-definition displays. -
Environmentally Friendly
The cable is compliant with RoHS standards, making it a safe choice for both users and the environment.
- StarTech.com 3m Certified DisplayPort 1.2 Cable M/M with Latches DP 4k - DisplayPort cable - 3 m
- DisplayPort cable
- Technology
- Shielded
- Latched, molded
- Length
- 3 m
- Connector
- DisplayPort - male
- Connector (Second End)
- RoHS, NEC-CMG
- Black
- Limited lifetime warranty
- DisplayPort cable
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Latched, molded
- Length
- 3 m
- Black
- Connector
- 20 pin DisplayPort - male
- RoHS, NEC-CMG
StarTech.com 5m Long DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £16.94 |
StarTech.com 2m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £9.57 |
StarTech.com 1m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £5.83 |
StarTech.com 3m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £15.35 |
StarTech.com 7m DisplayPort Cable with Latches - M/M | In Stock | £11.82 |
