StarTech.com 2m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k
Quicklinx: 7RPPWS00 Mfr#: DISPL2M
Type: DisplayPort
Length: 2m
20 In Stock
£9.29 ex VAT
£11.14 inc VAT
Create high-resolution 4k x 2k connections with HBR2 support between your DisplayPort-equipped devices. The DISPL2M 2m DisplayPort 1.2 Cable with latches provides a secure, connection between your DisplayPort-equipped devices and is capable of providing higher performance than either HDMI or dual link DVI.
The DP cable supports high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz with a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
  • Durable construction
    This cable features aluminum mylar foil with braid shielding, providing a strong and reliable connection.
  • Secure connection
    The latched design of the connectors ensures they remain firmly attached, reducing the risk of disconnection.
  • High-resolution support
    Capable of delivering resolutions up to 4K, this cable is perfect for users who require high-quality video output for gaming, presentations, or professional applications.
StarTech 2m Certified DisplayPort 1.2 Cable M/M with Latches DP 4k - DisplayPort cable - 2 m
DisplayPort cable
Shielded
Latched
Cable Length
2 m
Connector
DisplayPort - male
Connector (Second End)
DisplayPort - male
RoHS
DisplayPort cable
Shielded
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Latched
Cable Length
2 m
Connector
20 pin DisplayPort - male
RoHS
7RPP StarTech.com 5m Long DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £16.55
7RPP StarTech.com 2m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £9.29
7RPP StarTech.com 1m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £5.85
7RPP StarTech.com 3m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £15.00
7RPP StarTech.com 7m DisplayPort Cable with Latches - M/M In Stock £11.82
Type: DisplayPort
Length: 2m
