StarTech.com 2m/6.6 ft Premium High Speed HDMI Cable with Ethernet
Quicklinx: FKF6WS00 Mfr#: RHDMM2MP
Length: 2m
22 In Stock
£15.69 ex VAT
£18.82 inc VAT
This High Speed HDMI Cable with Ethernet withstands the daily demands of connecting your HDMI devices. Tested to endure strenuous wear and tear, the rugged cable is a must-have for both business and consumer applications.
The HDMI Premium Certified cable has aramid fiber reinforcement that braces it from the stress of frequent bends. This also lets the cable flex without over-stretching or damaging the core of the cable.
Cable Key Features. Aramid fiber adds strength and durability to the cable. Insulated conductors reduce friction, provide more flexibility. EMI protection with aluminum-mylar foil with braided shielding. TPE cable jacket is more flexible than a standard PVC cable.
The cable is constructed to prevent the connector from separating from the jacket. The extra-long strain relief molding is tested to withstand over 10,000+ bend cycles at a 180° angle.
Connector Key Features. HDMI gold plated connector with metal shield protects the circuit board from EMI and reinforces the connection point. Strain relief tested to tolerate over 10,000+ bend cycles at a 180° angle.
Supporting all HDMI 2.0 specifications, this HDMI Premium Certified cable supports resolutions up to 4K 60Hz with a bandwidth of up to 18Gbps. The HDMI cable also supports HDR for higher contrast ratio and vivid colors providing an enriched and enjoyable viewing experience.
  • Built for Daily Use
  • Flexible Strain Relief
  • Connector Key Features • HDMI gold plated connector with metal shield protects the circuit board from EMI and reinforces the connection point • Strain relief tested to tolerate over 10,000+ bend cycles at a 180° angle
    Supporting all HDMI 2.0 specifications, this HDMI Premium Certified cable supports resolutions up to 4K 60Hz with a bandwidth of up to 18Gbps. The HDMI cable also supports HDR for higher contrast ratio and vivid colors providing an enriched and enjoyable viewing experience. RHDMM2MP is backed by a StarTech.com lifetime warranty and free lifetime technical support. Note: DuPont and Kevlar are trademarks or registered trademarks of E.I. du Pont de Nemours and Company.
StarTech.com 2m Premium Certified HDMI 2.0 Cable with Ethernet, Durable High Speed UHD 4K 60Hz HDR 10, 6ft Rugged M/M HDMI Cord with Aramid Fiber, TPE, Ultra HD Monitors, TVs & Displays - Heavy duty HDMI cable - HDMI cable with Ethernet - 2 m
Cable
Premium High Speed - HDMI cable with Ethernet
American Wire Gauge (AWG)
30
Length
2 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
4K format support, HDR support, EMI/RFI protection
Works With Chromebook
P/N: TB3DKM2HDL
Cable Type
30
Jacket Material
PVC
Shielding Material
Length
2 m
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
RoHS, WEEE, REACH
Shipping Width
18.2 cm
Shipping Depth
15 cm
Shipping Height
2 cm
Limited warranty - lifetime
P/N: TB3DKM2HDL
FKF6 StarTech.com Triple Monitor Desk Mount In Stock £180.85
FKF6 StarTech.com Triple Monitor Desk Mount In Stock £169.08
FKF6 StarTech.com Crossbar Dual Monitor Stand In Stock £86.32
Length: 2m
