StarTech.com Triple Monitor Desk Mount
Quicklinx: J1JTWS00 Mfr#: 3M1A3SG-MONITOR-ARM
14 In Stock
£192.56 ex VAT
£231.07 inc VAT
Enhance your workspace with the StarTech.com Crossbar Triple Monitor Desk Mount, designed for flexibility and efficiency. This mounting kit supports three LCD displays ranging from 17" to 27", allowing for a seamless multitasking experience. With features like 360° rotation, swivel, and tilt adjustments, it offers the perfect viewing angles to suit your needs. The built-in cable management system ensures your workspace remains tidy, while the construction of aluminum, plastic, and steel ensures stability and durability. Easy to install, it comes with all necessary tools and screws, making it a great addition to any professional setting.
  • Versatile adjustments
    With capabilities for extension, pivot, rotation up to 360°, swivel from -10° to 10°, and tilt from -15° to 5°, this triple monitor desk mount offers flexibility to find the perfect viewing angles for productivity and comfort.
  • Robust build quality
    Crafted from a combination of aluminum, plastic, and steel, the Crossbar Triple Monitor Desk Mount is designed for durability and stability, securely supporting three LCD displays ranging from 17" to 27".
  • Efficient cable management
    Featuring a built-in cable management channel, this mounting kit ensures that your workspace remains tidy and organized, free from the clutter of cables.
  • Easy installation
    The package includes all necessary assembly tools and a comprehensive selection of screws, making the setup process straightforward and hassle-free for a seamless integration into your workspace.
StarTech.com Crossbar Triple Monitor Desk Mount, VESA 75x75/100x100 mounting kit - adjustable arm - for 3 LCD displays - triple monitor mount - black
Mounting kit (adjustable arm) - desk-mountable
63 cm x 140 cm
Adjustable Height
26.5-59.5 cm
Tilt
-15° to 5°
Rotation
360°
Swivel
-10° to 10°
Adjustments
Pivot, extension
8.4 kg
Recommended Use
3 LCD displays
Recommended Display Size
17"-27"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
6 kg
Material
Plastic, aluminium, steel
Package Content
Hex key (4mm), hex key (3mm), 12 x M4x12 screws, 2 x M5x8 screws, hex key (6mm), swivel arm, mounting base, 6 x cable management clip, 2 hand knobs, 3 x VESA monitor mounts, 12 x M5x12 screws, tool holder, spring arm, base pad, 3 x crossbars, grab handle, 2 x desk clamp discs, 2 x desk clamps, 10 x counter-sink screws, 4 x button head screws, 2 x M4x10 screws, 12 x washers, 2 x washers (small), 8 x hook and loop straps
5-year warranty
63 cm
140 cm
Adjustable Height
26.5-59.5 cm
8.4 kg
Material
Package Content
AV Furniture
Mounting kit
Design
Adjustable arm
Recommended Use
3 LCD displays
Placing / Mounting
Desk-mountable
Cable Management
Cable management channel
17"-27"
Tilt
-15° to 5°
Rotation
360°
Swivel
-10° to 10°
Adjustments
Pivot, extension
Max Load Weight
6 kg
Assembly Required
Dimensions & Weight Details
33 cm x 61 cm x 15 cm / 10 kg
Limited warranty - 5 years
J1JT StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £75.65
J1JT StarTech.com 24" Monitor Privacy Screen In Stock £88.27
J1JT StarTech.com 27" Monitor Privacy Screen In Stock £112.29
J1JT StarTech.com 25" Monitor Privacy Screen In Stock £70.52
