StarTech.com Dual Monitor Vertical Mount
Quicklinx: J4KJWS00 Mfr#: H2MPV-MONITOR-MOUNT
10 In Stock
£121.00 ex VAT
£145.20 inc VAT
The Desk Mount for 2x Vertically Stacked Monitors by StarTech.com is designed to enhance your workspace with a robust and flexible mounting solution. This mounting kit can accommodate two LCD displays or curved LCD displays, ranging from 17 to 49 inches. Constructed from durable plastic and steel, it ensures a sturdy setup while providing integrated cable management to keep your workspace tidy. Its versatile adjustments allow for height, tilt, swivel, and rotation, accommodating a variety of viewing angles. With a maximum load weight of 32 kg, it supports your monitors securely. Additionally, this desk-mountable design features a quick release mechanism, making it easy to install and reposition the monitors as needed.
  • Sturdy construction
    Made from high-quality plastic and steel, this mount ensures reliability and stability for your monitors.
  • Flexible adjustments
    Enjoy a wide range of adjustments including height, tilt, swivel, and rotation, allowing for optimal viewing angles.
  • Integrated cable management
    Keep cables organized and out of sight with the built-in cable management system, enhancing the overall aesthetic of your workspace.
  • Heavy load capacity
    This mount can support a maximum load weight of 32 kg, making it suitable for a variety of monitor setups.
  • Multiple display configurations
    Easily switch between portrait and landscape orientations to suit your work preferences and needs.
StarTech.com Desk Mount For 2x Vertically Stacked Monitors, Dual 49", TAA mounting kit - for 2 LCD displays/ curved LCD displays - quick release - black - TAA Compliant
Mounting kit - desk-mountable
Mounting Components
C-clamp 25-100 mm, pole assembly, pole cap, 2 VESA mount, 2 VESA plates, 2 support collars
92.2 cm x 21.4 cm x 92.2 cm
Adjustable Height
Up to 69.6 cm
Tilt
-90° to 90°
Rotation
-180° to 180°
Swivel
-90° to 90°
Adjustments
Height, tilt, swivel, rotation
7 kg
Recommended Use
Recommended Display Size
17"-49" (ultrawide)
VESA Mounting Interface
75 x 75 mm, 100 x 100 mm
Max Load Weight
32 kg
Material
Steel, plastic
TAA Compliant
Package Content
8 x M4 x 10 mm screw, 8 x M4 x 16 mm screw, 8 x 3/8" x 1/2" screw, 8 x spacers, M3 hex key, M6 hex key, wrench
5-year warranty
92.2 cm
21.4 cm
92.2 cm
Adjustable Height
Up to 69.6 cm
7 kg
Material
Steel, plastic
Package Content
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Placing / Mounting
Desk-mountable
Cable Management
17"-49" (ultrawide)
Tilt
-90° to 90°
Rotation
-180° to 180°
Swivel
-90° to 90°
Adjustments
Max Load Weight
32 kg
TAA Compliant
Finish
Powder coated
Details
Landscape orientation, portrait orientation
Dimensions & Weight Details
83.5 cm x 21.3 cm x 16 cm / 7.3 kg
Limited warranty - 5 years
J4KJ StarTech.com 24" Monitor Privacy Screen In Stock £79.81
J4KJ StarTech.com 27" Monitor Privacy Screen In Stock £101.53
J4KJ StarTech.com 25" Monitor Privacy Screen In Stock £71.91
J4KJ StarTech.com Privacy Screen Dell U3824DW In Stock £147.94
