StarTech.com 25U 36in Server Rack Cabinet
Quicklinx: BR08WS00 Mfr#: RK2536BKF
£712.74 ex VAT
£855.28 inc VAT
Easy to transport and quick assemble 25U secure server rack cabinet. The RK2536BKF DuraRak 25U 36-inch (depth) server cabinet/rack features a vented glass front door and mesh rear door, to provide devices stored in the cabinet with cost-effective passive cooling.
Supporting a total load capacity of 815 kgs (1800 lbs), the server rack is constructed of steel and aluminum to ensure a sturdy platform for valuable server/networking equipment. The included casters make this product a flexible rack solution for any IT environment or server closet.
The rack is easy to assemble at the point of installation for rapid deployment and features a flat-packed design that helps to minimize shipping costs.
  • Save money, with a cost effective, compact shipping container
    The cabinet comes in a flat packed box to reduce shipping volume, which significantly reduces your costs in shipping. Plus, because the rack is packaged efficiently, you can easily store the cabinet, for deployment at a later date.
StarTech.com 25U Network Rack Cabinet on Wheels - 36in Deep - Portable 19in 4 Post Network Rack Enclosure for Data & IT Computer Equipment w/ Casters (RK2536BKF) - rack - 25U
Rack
Height (Rack Units)
25U
Product Material
Aluminium, steel, acrylic
Mesh rear door, vented
Rack
Product Material
Height (Rack Units)
25U
Weight Limit
815 kg
Limited warranty: - lifetime
BR08 StarTech.com 16 Port 1U Rackmount USB PS/2 KVM Switch with OSD In Stock £253.47
BR08 StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg In Stock £92.31
BR08 StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet In Stock £44.03
BR08 StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails In Stock £76.90
BR08 StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £11.90
BR08 StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £29.91
BR08 StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £30.44
BR08 StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD In Stock £452.75
BR08 StarTech.com 1U Rack Blank Panel for 19in Server Racks and Cabinets In Stock £7.50
BR08 StarTech.com 2U Rack Blank Panel for 19in Server Racks and Cabinets In Stock £11.24
BR08 StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.09
BR08 StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £27.99
BR08 StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £52.23
BR08 StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £55.25
BR08 StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg In Stock £25.06
BR08 StarTech.com 22in Black Deep Sliding Server Rack Cabinet Shelf In Stock £88.98
BR08 StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £514.22
BR08 StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £273.74
BR08 StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £309.46
BR08 StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch In Stock £600.89
BR08 StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg In Stock £84.75
BR08 StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £61.35
BR08 StarTech.com 2U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £70.88
BR08 StarTech.com 3U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £75.13
BR08 StarTech.com 12U 36in Knock-Down Server Rack Cabinet with Casters In Stock £353.02
BR08 StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg In Stock £71.34
BR08 StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg In Stock £79.75
BR08 StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg In Stock £55.31
BR08 StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg In Stock £43.20
BR08 StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £36.09
BR08 StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £50.11
BR08 StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) In Stock £3.06
BR08 StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) In Stock £4.23
BR08 StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £6.20
BR08 StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £38.24
BR08 StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 50lbs / 22.7kg In Stock £154.86
BR08 StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 125lbs / 56.7kg In Stock £157.64
BR08 StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £46.00
BR08 StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £17.40
BR08 StarTech.com 25U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks In Stock £192.50
BR08 StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £22.90
BR08 StarTech.com 12U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks In Stock £165.22
BR08 StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £55.20
BR08 StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £29.89
BR08 StarTech.com Portable Server Rack - 9U In Stock £261.41
BR08 StarTech.com 25U 36in Server Rack Cabinet In Stock £712.74
BR08 StarTech.com 100 Pkg M5 Cage Nuts In Stock £25.95
BR08 StarTech.com 50 Pkg M6 Cage Nuts In Stock £19.69
BR08 StarTech.com 100 Pkg M5 Cage Nuts In Stock £9.55
BR08 StarTech.com 50 Pkg M5 Cage Nuts In Stock £5.39
BR08 StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £52.24
BR08 StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £27.56
BR08 StarTech.com 50 Pkg M5 Mounting Screws In Stock £15.48
BR08 StarTech.com 100 Pkg M5 Mounting Screws In Stock £28.96
BR08 StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.16
BR08 StarTech.com 100 Pkg M6 Cage Nuts In Stock £26.89
BR08 StarTech.com 100 Pkg M6 Cage Nuts In Stock £26.45
BR08 StarTech.com 19in Cable Management Panel In Stock £23.58
BR08 StarTech.com 15U Server Rack Cabinet - Includes Casters and Leveling Feet In Stock £424.62
BR08 StarTech.com 18U Server Rack Cabinet - Includes Casters and Leveling Feet In Stock £468.65
BR08 StarTech.com M6 Mounting Screws 50Pack In Stock £16.78
Price Range Ex VAT: £500 - £750
