StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails
Quicklinx: 76LHWS00 Mfr#: ADJDINKIT
10 In Stock
£84.93 ex VAT
£101.91 inc VAT
Easily mount any DIN Rail equipment in a standard 19" rack. The ADJDINKIT Adjustable Rack Mount DIN Rail Kit with Top Hat/Mini/G Rails makes mounting your DIN-rail equipment in a 19-inch server rack/cabinet or wall plate simple, without wasting space due to special bracket requirements for each piece of equipment. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
This 19-inch DIN Rail Mounting Kit includes the three most commonly used DIN rail systems: Top-Hat, Miniature Top-Hat, and G-Type.
StarTech.com 2U DIN Rail Kit for Standard 19" Rack - Adjustable Depth Rackmount DIN Rail with Top Hat, Mini, G Rails (ADJDINKIT) - rack rail kit - 2U
Rack rail kit
Rack Size
19"
Height (Rack Units)
2U
Product Material
Steel
48.3 cm x 35.8 cm x 8.9 cm
1.72 kg
P/N: 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12U, 4POSTRACK25U, 4POSTRACK42, RK1233BKM, RK1236BKF, RK12OD2, RK1833BKM, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BKB, RK4242BK24, RK4242BK30, RK4OD, RK619WALL, RK619WALLGB, RK8OD, RK960CP, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
Rack rail kit
Product Material
Steel
Rack Size
19"
Height (Rack Units)
2U
48.3 cm
35.8 cm
8.9 cm
1.72 kg
Mounting Kit
Included
UL, RoHS
Limited warranty: - lifetime
P/N: 2636CABINET, 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1233BKM, RK1236BKF, RK12OD, RK12OD2, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK4OD, RK619WALL, RK619WALLGB, RK8OD, RK960CP, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
76LH StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg In Stock £96.93
76LH StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails In Stock £84.93
76LH StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £31.00
76LH StarTech.com 1U Rack Blank Panel for 19in Server Racks and Cabinets In Stock £7.49
76LH StarTech.com 4U Black Steel Storage Drawer for 19in Racks and Cabinets In Stock £101.34
76LH StarTech.com 19in Cable Management Panel In Stock £23.30
