The CABSHELF1U 1U (Black) Universal Fixed Server Rack Cabinet Shelf lets you add a compact fixed storage shelf to any standard 19-inch server rack or cabinet with front mount options. Constructed using SPCC commercial grade cold-rolled steel, this durable fixed rack shelf can hold up to 15kg (33lbs) of equipment - a perfect solution for storing small form non-rackmount equipment, tools, peripherals or accessories in your rack, to keep them readily accessible.
Sturdy construction
Made from cold-rolled steel, this rack shelf provides strength and support for your equipment, ensuring longevity and reliability in demanding environments. -
Space-efficient design
With a height of just 1U, this shelf allows for an organized setup in server racks without occupying excessive vertical space. -
Ample weight capacity
Able to support up to 15 kg, this shelf is suitable for various devices, making it versatile for different server configurations.
- StarTech.com 1U Server Rack Cabinet Shelf, 7in Deep Fixed Cantilever Tray, Rackmount Shelf for 19" AV/Data/Network Equipment Enclosure with Cage Nuts & Screws, 33lbs Weight Capacity - 1U Rack Shelf 7" Deep (CABSHELF1U) - rack shelf - 1U
- Product Type
- Rack shelf
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 1U
- Product Material
- Cold-rolled steel
- Limited lifetime warranty
- Designed For
- P/N: 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25U, 4POSTRACK42, RK1219SIDEM, RK1233BKM, RK1236BKF, RK12OD2, RK1833BKM, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BKB, RK4242BK24, RK4242BK30, RK819SIDEM, RK8OD, RK960CP, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
- Product Type
- Rack shelf
- Product Material
- Cold-rolled steel
- Rack Size
- 19"
- 1U
- Black
- Weight Limit
- 15 kg
- Limited warranty: - lifetime
- Designed For
- P/N: 2636CABINET, 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1219SIDEM, RK1233BKM, RK1236BKF, RK12OD, RK12OD2, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK819SIDEM, RK8OD, RK960CP, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg | In Stock | £92.31 |
StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £11.90 |
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £30.85 |
StarTech.com Black Standard Universal Server Rack Cabinet Shelf | In Stock | £29.96 |
StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet | In Stock | £14.09 |
StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £27.55 |
StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £52.23 |
StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £55.25 |
StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg | In Stock | £24.68 |
StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg | In Stock | £84.75 |
StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg | In Stock | £55.31 |
StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg | In Stock | £43.20 |
StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg | In Stock | £35.53 |
StarTech.com Vented 1U Rack Shelf - 7in | In Stock | £23.79 |
StarTech.com 1U Rack Shelf - 10in | In Stock | £24.16 |
StarTech.com Vented 1U Rack Shelf - 16 in. | In Stock | £30.58 |
StarTech.com Vented 1U Rack Shelf - 10in | In Stock | £21.29 |
StarTech.com 1U Server Rack Shelf - 16in. Deep - EIA/ECA-310 Compliant | In Stock | £38.79 |
StarTech.com 1U Vented Shelf 12in | In Stock | £33.08 |
StarTech.com 1U Vented Shelf 20in | In Stock | £54.90 |
StarTech.com 2U Vented Shelf 14in | In Stock | £61.21 |
StarTech.com 2-Pack 1U Rack Shelf, Vented | In Stock | £54.63 |
