StarTech.com 25U 36in Server Rack Cabinet
Quicklinx: BR08WS00 Mfr#: RK2536BKF
Hurry, only 2 left in stock!
£720.42 ex VAT
£864.50 inc VAT
Easy to transport and quick assemble 25U secure server rack cabinet. The RK2536BKF DuraRak 25U 36-inch (depth) server cabinet/rack features a vented glass front door and mesh rear door, to provide devices stored in the cabinet with cost-effective passive cooling.
Supporting a total load capacity of 815 kgs (1800 lbs), the server rack is constructed of steel and aluminum to ensure a sturdy platform for valuable server/networking equipment. The included casters make this product a flexible rack solution for any IT environment or server closet.
The rack is easy to assemble at the point of installation for rapid deployment and features a flat-packed design that helps to minimize shipping costs.
  • Save money, with a cost effective, compact shipping container
    The cabinet comes in a flat packed box to reduce shipping volume, which significantly reduces your costs in shipping. Plus, because the rack is packaged efficiently, you can easily store the cabinet, for deployment at a later date.
StarTech.com 25U Network Rack Cabinet on Wheels - 36in Deep - Portable 19in 4 Post Network Rack Enclosure for Data & IT Computer Equipment w/ Casters (RK2536BKF) - rack - 25U
Rack
Height (Rack Units)
25U
Product Material
Aluminium, steel, acrylic
Mesh rear door, vented
Rack
Product Material
Height (Rack Units)
25U
Weight Limit
815 kg
Limited warranty: - lifetime
BR08 StarTech.com 16 Port 1U Rackmount USB PS/2 KVM Switch with OSD In Stock £488.55
BR08 StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg In Stock £96.93
BR08 StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails In Stock £84.93
BR08 StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £12.34
BR08 StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.51
BR08 StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £31.10
BR08 StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD In Stock £477.22
BR08 StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) In Stock £335.92
BR08 StarTech.com 1U Rack Blank Panel for 19in Server Racks and Cabinets In Stock £7.49
BR08 StarTech.com 2U Rack Blank Panel for 19in Server Racks and Cabinets In Stock £11.75
BR08 StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.45
BR08 StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £28.56
BR08 StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.09
BR08 StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.23
BR08 StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg In Stock £25.89
BR08 StarTech.com 22in Black Deep Sliding Server Rack Cabinet Shelf In Stock £92.13
BR08 StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £542.00
BR08 StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £284.45
BR08 StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £317.76
BR08 StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch In Stock £635.38
BR08 StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg In Stock £86.73
BR08 StarTech.com 4U Black Steel Storage Drawer for 19in Racks and Cabinets In Stock £101.34
BR08 StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £63.29
BR08 StarTech.com 3U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £77.90
BR08 StarTech.com 12U 36in Knock-Down Server Rack Cabinet with Casters In Stock £366.90
BR08 StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £33.04
BR08 StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg In Stock £73.91
BR08 StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg In Stock £82.73
BR08 StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg In Stock £55.31
BR08 StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg In Stock £44.71
BR08 StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £37.48
BR08 StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £52.08
BR08 StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) In Stock £3.06
BR08 StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) In Stock £4.36
BR08 StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £6.45
BR08 StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £39.94
BR08 StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 50lbs / 22.7kg In Stock £162.10
BR08 StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £46.00
BR08 StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £17.96
BR08 StarTech.com 25U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks In Stock £199.11
BR08 StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £23.35
BR08 StarTech.com 12U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks In Stock £170.86
BR08 StarTech.com 1U Server Rack Panel In Stock £11.99
BR08 StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £57.09
BR08 StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £30.44
BR08 StarTech.com Portable Server Rack - 9U In Stock £261.41
BR08 StarTech.com 25U 36in Server Rack Cabinet In Stock £720.42
BR08 StarTech.com 100 Pkg M5 Cage Nuts In Stock £26.80
BR08 StarTech.com 50 Pkg M6 Cage Nuts In Stock £20.46
BR08 StarTech.com 100 Pkg M5 Cage Nuts In Stock £28.99
BR08 StarTech.com 50 Pkg M5 Cage Nuts In Stock £15.59
BR08 StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £54.01
BR08 StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £29.06
BR08 StarTech.com 50 Pkg M5 Mounting Screws In Stock £16.04
BR08 StarTech.com 100 Pkg M5 Mounting Screws In Stock £29.99
BR08 StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.75
BR08 StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.29
BR08 StarTech.com 100 Pkg M6 Cage Nuts In Stock £28.49
BR08 StarTech.com 19in Cable Management Panel In Stock £23.30
BR08 StarTech.com 15U Server Rack Cabinet - Includes Casters and Leveling Feet In Stock £438.39
BR08 StarTech.com 18U Server Rack Cabinet - Includes Casters and Leveling Feet In Stock £468.65
BR08 StarTech.com M6 Mounting Screws 50Pack In Stock £16.78
Price Range Ex VAT: £500 - £750
