Easy to transport and quick assemble 25U secure server rack cabinet. The RK2536BKF DuraRak 25U 36-inch (depth) server cabinet/rack features a vented glass front door and mesh rear door, to provide devices stored in the cabinet with cost-effective passive cooling.
Supporting a total load capacity of 815 kgs (1800 lbs), the server rack is constructed of steel and aluminum to ensure a sturdy platform for valuable server/networking equipment. The included casters make this product a flexible rack solution for any IT environment or server closet.
The rack is easy to assemble at the point of installation for rapid deployment and features a flat-packed design that helps to minimize shipping costs.
Save money, with a cost effective, compact shipping container
The cabinet comes in a flat packed box to reduce shipping volume, which significantly reduces your costs in shipping. Plus, because the rack is packaged efficiently, you can easily store the cabinet, for deployment at a later date.
- StarTech.com 25U Network Rack Cabinet on Wheels - 36in Deep - Portable 19in 4 Post Network Rack Enclosure for Data & IT Computer Equipment w/ Casters (RK2536BKF) - rack - 25U
- Product Type
- Rack
- Height (Rack Units)
- 25U
- Product Material
- Aluminium, steel, acrylic
- Mesh rear door, vented
- Limited lifetime warranty
- Product Type
- Rack
- Product Material
- 25U
- Weight Limit
- 815 kg
- Limited warranty: - lifetime
StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg | In Stock | £94.63 |
StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet | In Stock | £45.84 |
StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails | In Stock | £79.45 |
StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £12.20 |
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £30.66 |
StarTech.com Black Standard Universal Server Rack Cabinet Shelf | In Stock | £30.71 |
StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £464.07 |
StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) | In Stock | £351.41 |
StarTech.com 1U Rack Blank Panel for 19in Server Racks and Cabinets | In Stock | £8.24 |
StarTech.com 2U Rack Blank Panel for 19in Server Racks and Cabinets | In Stock | £11.53 |
StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet | In Stock | £14.44 |
StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £28.24 |
StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £54.39 |
StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £57.53 |
StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg | In Stock | £25.30 |
StarTech.com 22in Black Deep Sliding Server Rack Cabinet Shelf | In Stock | £93.48 |
StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables | In Stock | £527.07 |
StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £280.59 |
StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables | In Stock | £324.85 |
StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch | In Stock | £543.36 |
StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg | In Stock | £86.88 |
StarTech.com 4U Black Steel Storage Drawer for 19in Racks and Cabinets | In Stock | £102.81 |
StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails | In Stock | £62.88 |
StarTech.com 2U Fixed 19" Adjustable Depth Universal Server Rack Rails | In Stock | £72.65 |
StarTech.com 3U Fixed 19" Adjustable Depth Universal Server Rack Rails | In Stock | £77.01 |
StarTech.com 12U 36in Knock-Down Server Rack Cabinet with Casters | In Stock | £363.55 |
StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel | In Stock | £15.50 |
StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg | In Stock | £76.49 |
StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg | In Stock | £81.75 |
StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg | In Stock | £56.70 |
StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg | In Stock | £44.28 |
StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg | In Stock | £37.00 |
StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg | In Stock | £51.38 |
StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) | In Stock | £3.06 |
StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) | In Stock | £4.24 |
StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) | In Stock | £6.36 |
StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel | In Stock | £38.59 |
StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 50lbs / 22.7kg | In Stock | £158.72 |
StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 125lbs / 56.7kg | In Stock | £162.14 |
StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel | In Stock | £47.16 |
StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover | In Stock | £17.75 |
StarTech.com 25U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks | In Stock | £197.30 |
StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover | In Stock | £23.11 |
StarTech.com 12U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks | In Stock | £169.35 |
StarTech.com 100 Pkg M6 Screws & Cage Nuts | In Stock | £56.58 |
StarTech.com 50 Pkg M6 Screws & Cage Nuts | In Stock | £30.63 |
StarTech.com Portable Server Rack - 9U | In Stock | £267.95 |
StarTech.com 25U 36in Server Rack Cabinet | In Stock | £730.55 |
StarTech.com 50 Pkg M6 Cage Nuts | In Stock | £20.19 |
StarTech.com 50 Pkg M5 Cage Nuts | In Stock | £5.39 |
StarTech.com 100 Pkg M5 Screws & Cage Nuts | In Stock | £53.55 |
StarTech.com 50 Pkg M5 Screws & Cage Nuts | In Stock | £28.25 |
StarTech.com 100 Pkg M5 Mounting Screws | In Stock | £29.69 |
StarTech.com 50 Pkg M6 Mounting Screws | In Stock | £16.56 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £27.01 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £27.11 |
Startech.com 100 Pkg M6 Mounting Screws | In Stock | £26.84 |
StarTech.com 19in Cable Management Panel | In Stock | £24.18 |
StarTech.com 15U Server Rack Cabinet - Includes Casters and Leveling Feet | In Stock | £435.23 |
StarTech.com 18U Server Rack Cabinet - Includes Casters and Leveling Feet | In Stock | £490.27 |
StarTech.com M6 Mounting Screws 50Pack | In Stock | £16.56 |
