StarTech.com 25U 36in Server Rack Cabinet
Quicklinx: BR08WS00 Mfr#: RK2536BKF
£730.55 ex VAT
£876.66 inc VAT
Easy to transport and quick assemble 25U secure server rack cabinet. The RK2536BKF DuraRak 25U 36-inch (depth) server cabinet/rack features a vented glass front door and mesh rear door, to provide devices stored in the cabinet with cost-effective passive cooling.
Supporting a total load capacity of 815 kgs (1800 lbs), the server rack is constructed of steel and aluminum to ensure a sturdy platform for valuable server/networking equipment. The included casters make this product a flexible rack solution for any IT environment or server closet.
The rack is easy to assemble at the point of installation for rapid deployment and features a flat-packed design that helps to minimize shipping costs.
  • Save money, with a cost effective, compact shipping container
    The cabinet comes in a flat packed box to reduce shipping volume, which significantly reduces your costs in shipping. Plus, because the rack is packaged efficiently, you can easily store the cabinet, for deployment at a later date.
StarTech.com 25U Network Rack Cabinet on Wheels - 36in Deep - Portable 19in 4 Post Network Rack Enclosure for Data & IT Computer Equipment w/ Casters (RK2536BKF) - rack - 25U
Rack
Height (Rack Units)
25U
Product Material
Aluminium, steel, acrylic
Mesh rear door, vented
Rack
Product Material
Height (Rack Units)
25U
Weight Limit
815 kg
Limited warranty: - lifetime
BR08 StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg In Stock £94.63
BR08 StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet In Stock £45.84
BR08 StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails In Stock £79.45
BR08 StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £12.20
BR08 StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.66
BR08 StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £30.71
BR08 StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD In Stock £464.07
BR08 StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) In Stock £351.41
BR08 StarTech.com 1U Rack Blank Panel for 19in Server Racks and Cabinets In Stock £8.54
BR08 StarTech.com 2U Rack Blank Panel for 19in Server Racks and Cabinets In Stock £11.53
BR08 StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £28.24
BR08 StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.39
BR08 StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.53
BR08 StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg In Stock £25.30
BR08 StarTech.com 22in Black Deep Sliding Server Rack Cabinet Shelf In Stock £91.53
BR08 StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £527.07
BR08 StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £280.59
BR08 StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £317.20
BR08 StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch In Stock £543.36
BR08 StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg In Stock £86.88
BR08 StarTech.com 4U Black Steel Storage Drawer for 19in Racks and Cabinets In Stock £100.66
BR08 StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £62.88
BR08 StarTech.com 2U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £75.35
BR08 StarTech.com 3U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £77.01
BR08 StarTech.com 12U 36in Knock-Down Server Rack Cabinet with Casters In Stock £363.55
BR08 StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £15.50
BR08 StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg In Stock £74.28
BR08 StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg In Stock £81.75
BR08 StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg In Stock £56.70
BR08 StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg In Stock £44.28
BR08 StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £37.00
BR08 StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £51.38
BR08 StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) In Stock £3.06
BR08 StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) In Stock £4.68
BR08 StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £6.36
BR08 StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £38.59
BR08 StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 50lbs / 22.7kg In Stock £158.72
BR08 StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 125lbs / 56.7kg In Stock £162.14
BR08 StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £47.16
BR08 StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £17.75
BR08 StarTech.com 25U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks In Stock £197.30
BR08 StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £23.11
BR08 StarTech.com 12U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks In Stock £169.35
BR08 StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £56.58
BR08 StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £30.63
BR08 StarTech.com Portable Server Rack - 9U In Stock £267.95
BR08 StarTech.com 25U 36in Server Rack Cabinet In Stock £730.55
BR08 StarTech.com 50 Pkg M6 Cage Nuts In Stock £20.19
BR08 StarTech.com 100 Pkg M5 Cage Nuts In Stock £9.55
BR08 StarTech.com 50 Pkg M5 Cage Nuts In Stock £5.39
BR08 StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £53.55
BR08 StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £28.25
BR08 StarTech.com 100 Pkg M5 Mounting Screws In Stock £29.69
BR08 StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.56
BR08 StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.11
BR08 Startech.com 100 Pkg M6 Mounting Screws In Stock £26.84
BR08 StarTech.com 19in Cable Management Panel In Stock £24.18
BR08 StarTech.com 15U Server Rack Cabinet - Includes Casters and Leveling Feet In Stock £435.23
BR08 StarTech.com 18U Server Rack Cabinet - Includes Casters and Leveling Feet In Stock £480.37
BR08 StarTech.com M6 Mounting Screws 50Pack In Stock £16.56
Price Range Ex VAT: £500 - £750
