StarTech.com 24in Internal 5 pin USB IDC Motherboard Header Cable F/F
Quicklinx: 89D0WS00 Mfr#: USBINT5PIN24
Length: 60.7cm
42 in stock
£3.34 ex VAT
£4.00 inc VAT
Connect a front panel USB hub or card reader directly to a motherboard header connector. The USBINT5PIN24 Internal USB Cable features two 5-pin USB motherboard header connectors, enabling you to connect a front panel USB hub or card reader directly to the motherboard header ports.
This 24in/2ft cable provides a convenient solution for connecting multi-function front panels, or any device that relies on internal USB ports, directly to a motherboard or expansion card USB IDC (Header) connection, without having to install additional cards or run cables externally to the rear ports.
The 5-pin USB Header Cable is constructed of high quality materials and expertly constructed for durable performance.
StarTech.com 24in Internal 5 pin USB IDC Motherboard Header Cable F/F - USB cable - 60.7 cm
USB cable
Length
60.7 cm
Connector
5 pin IDC - female
Connector (Second End)
5 pin IDC - female
USB / USB 2.0
USB cable
American Wire Gauge (AWG)
24/28
Length
60.7 cm
Connector
5 pin IDC - female
5 pin IDC - female
USB / USB 2.0, RoHS
89D0 StarTech.com 1 ft Panel Mount USB Cable - USB A to Motherboard Header Cable F/F In Stock £4.21
89D0 StarTech.com 18in Internal 5 pin USB IDC Motherboard Header Cable – F/F In Stock £2.88
89D0 StarTech.com 2 Port USB Motherboard Header Adapter In Stock £9.30
89D0 StarTech.com 6in USB 2.0 Cable - USB A Female to USB Motherboard 4 Pin Header F/F In Stock £4.17
89D0 StarTech.com 24in Internal 5 pin USB IDC Motherboard Header Cable F/F In Stock £3.34
Length: 60.7cm
Price Range Ex VAT: 0 - 50
