StarTech.com 6in USB 2.0 Cable - USB A Female to USB Motherboard 4 Pin Header F/F
Quicklinx: 7ZMSWS00 Mfr#: USBMBADAPT
Length: 15cm
29 In Stock
£6.04 ex VAT
£7.24 inc VAT
This USB A Female to Motherboard Header Adapter features a 4-pin USB header connection, as well as a regular USB A (female) port, allowing you to connect internal USB devices directly to the motherboard header connection. The adapter cable offers a cost-effective solution for connecting multi-function front panels, or any device that relies on using an internal USB port.
StarTech.com 6in USB 2.0 A to USB 4 Pin to Motherboard Header Adapter F/F - USB cable - USB (F) to 4 pin USB 2.0 header (F) - USBMBADAPT - USB cable - USB to 4 pin USB 2.0 header - 15 cm
USB cable
Length
15 cm
Connector
4 pin USB Type A - female
Connector (Second End)
4 pin USB 2.0 header - female
P/N: 35FCREAD, 35FCREADBK, 35FCREADREM
USB cable
Length
15 cm
Connector
StarTech.com 35FCREAD, 35FCREADBK, 35FCREADREM
Length: 15cm
