StarTech.com 24in Internal 5 pin USB IDC Motherboard Header Cable F/F
Quicklinx: 89D0WS00 Mfr#: USBINT5PIN24
Length: 60.7cm
Type: Motherboard
£2.50 ex VAT
£3.00 inc VAT
Connect a front panel USB hub or card reader directly to a motherboard header connector. The USBINT5PIN24 Internal USB Cable features two 5-pin USB motherboard header connectors, enabling you to connect a front panel USB hub or card reader directly to the motherboard header ports.
This 24in/2ft cable provides a convenient solution for connecting multi-function front panels, or any device that relies on internal USB ports, directly to a motherboard or expansion card USB IDC (Header) connection, without having to install additional cards or run cables externally to the rear ports.
The 5-pin USB Header Cable is constructed of high quality materials and expertly constructed for durable performance.
  • Reliable connectivity
    The 24 in Internal 5 pin USB IDC Motherboard Header Cable is designed for dependable performance, ensuring that internal devices connect seamlessly for effective data transfer.
  • Flexible length
    At 2 ft long, this cable provides just the right length for various configurations, allowing for versatile setups within internal computer systems.
  • Environmentally friendly
    This cable is RoHS compliant, indicating it meets stringent standards for environmental safety, making it a responsible choice for consumers.
  • Easy integration
    With female connectors on both sides, this USB cable simplifies the process of connecting and extending internal USB ports within a motherboard.
  • Durable design
    Built with quality materials and 24/28 AWG wiring, this cable offers durability and resilience to meet the demands of internal applications.
StarTech.com 24in Internal 5 pin USB IDC Motherboard Header Cable F/F - USB cable - 5 pin IDC (F) to 5 pin IDC (F) - USB 2.0 - 2 ft - black - USBINT5PIN24 - USB cable - 5 pin IDC to 5 pin IDC - 60.7 cm
USB cable
Length
60.7 cm
Connector
5 pin IDC - female
Connector (Second End)
5 pin IDC - female
USB / USB 2.0
USB cable
American Wire Gauge (AWG)
24/28
Length
60.7 cm
Connector
5 pin IDC - female
5 pin IDC - female
USB / USB 2.0, RoHS
89D0 StarTech.com 1 ft Panel Mount USB Cable - USB A to Motherboard Header Cable F/F In Stock £5.55
89D0 StarTech.com 2 Port USB Motherboard Header Adapter In Stock £11.94
89D0 StarTech.com 6in USB 2.0 Cable - USB A Female to USB Motherboard 4 Pin Header F/F In Stock £6.15
89D0 StarTech.com 24in Internal 5 pin USB IDC Motherboard Header Cable F/F In Stock £2.50
Length: 60.7cm
Type: Motherboard
