Connect a front panel USB hub or card reader directly to a motherboard header connector. The USBINT5PIN24 Internal USB Cable features two 5-pin USB motherboard header connectors, enabling you to connect a front panel USB hub or card reader directly to the motherboard header ports.
This 24in/2ft cable provides a convenient solution for connecting multi-function front panels, or any device that relies on internal USB ports, directly to a motherboard or expansion card USB IDC (Header) connection, without having to install additional cards or run cables externally to the rear ports.
The 5-pin USB Header Cable is constructed of high quality materials and expertly constructed for durable performance.
- StarTech.com 24in Internal 5 pin USB IDC Motherboard Header Cable F/F - USB cable - 5 pin IDC (F) to 5 pin IDC (F) - USB 2.0 - 2 ft - black - USBINT5PIN24 - USB cable - 5 pin IDC to 5 pin IDC - 60.7 cm
- USB cable
- Length
- 60.7 cm
- Connector
- 5 pin IDC - female
- Connector (Second End)
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB cable
- American Wire Gauge (AWG)
- 24/28
- Length
- 60.7 cm
- Black
- Connector
- USB / USB 2.0, RoHS
StarTech.com 1 ft Panel Mount USB Cable - USB A to Motherboard Header Cable F/F | In Stock | £4.23 |
StarTech.com 18in Internal 5 pin USB IDC Motherboard Header Cable – F/F | In Stock | £2.89 |
StarTech.com 2 Port USB Motherboard Header Adapter | In Stock | £9.56 |
StarTech.com 6in USB 2.0 Cable - USB A Female to USB Motherboard 4 Pin Header F/F | In Stock | £4.19 |
StarTech.com 24in Internal 5 pin USB IDC Motherboard Header Cable F/F | In Stock | £3.29 |
