Connect a front panel USB hub or card reader directly to a motherboard header connector. The USBINT5PIN24 Internal USB Cable features two 5-pin USB motherboard header connectors, enabling you to connect a front panel USB hub or card reader directly to the motherboard header ports.
This 24in/2ft cable provides a convenient solution for connecting multi-function front panels, or any device that relies on internal USB ports, directly to a motherboard or expansion card USB IDC (Header) connection, without having to install additional cards or run cables externally to the rear ports.
The 5-pin USB Header Cable is constructed of high quality materials and expertly constructed for durable performance.
Reliable connectivity
The 24 in Internal 5 pin USB IDC Motherboard Header Cable is designed for dependable performance, ensuring that internal devices connect seamlessly for effective data transfer. -
Flexible length
At 2 ft long, this cable provides just the right length for various configurations, allowing for versatile setups within internal computer systems. -
Environmentally friendly
This cable is RoHS compliant, indicating it meets stringent standards for environmental safety, making it a responsible choice for consumers. -
Easy integration
With female connectors on both sides, this USB cable simplifies the process of connecting and extending internal USB ports within a motherboard. -
Durable design
Built with quality materials and 24/28 AWG wiring, this cable offers durability and resilience to meet the demands of internal applications.
- StarTech.com 24in Internal 5 pin USB IDC Motherboard Header Cable F/F - USB cable - 5 pin IDC (F) to 5 pin IDC (F) - USB 2.0 - 2 ft - black - USBINT5PIN24 - USB cable - 5 pin IDC to 5 pin IDC - 60.7 cm
- USB cable
- Length
- 60.7 cm
- Connector
- 5 pin IDC - female
- Connector (Second End)
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB cable
- American Wire Gauge (AWG)
- 24/28
- Length
- 60.7 cm
- Black
- Connector
- USB / USB 2.0, RoHS
StarTech.com 1 ft Panel Mount USB Cable - USB A to Motherboard Header Cable F/F | In Stock | £5.55 |
StarTech.com 2 Port USB Motherboard Header Adapter | In Stock | £11.94 |
StarTech.com 6in USB 2.0 Cable - USB A Female to USB Motherboard 4 Pin Header F/F | In Stock | £6.15 |
StarTech.com 24in Internal 5 pin USB IDC Motherboard Header Cable F/F | In Stock | £2.50 |
