StarTech.com 20m USB 2.0 Active Extension Cable - M/F
Quicklinx: 887WWS00 Mfr#: USB2AAEXT20M
Length: 20m
£58.83 ex VAT
£70.59 inc VAT
Extend the distance between a computer and a USB 2.0 device by 20 meters. The USB2AAEXT20M 20-meter Active USB 2.0 Extension Cable, offers one USB type-A (male) connector and one USB type-A (female) connector, and provides an active extension of USB 2.0 devices of up to 20-meters (66-feet).
An all-in-one cable for overcoming distance restrictions as well as power source limitations, the active USB 2.0 extension cable incorporates bus-powered active circuitry to ensure performance beyond the length limits of standard USB cables. Up to 2 of these cables can be daisy-chained together, allowing the connection to be extended a total of 40-meters. If necessary, the USB device can be powered from a wall outlet using the Universal AC power adapter provided with the cable.
StarTech.com 20m USB 2.0 Active Extension Cable - M/F - USB extension cable - USB (M) to USB (F) - USB 2.0 - 66 ft - active - black - USB2AAEXT20M - USB extension cable - USB to USB - 20 m
USB extension cable
Shielded
Active cable (signal regeneration)
Length
20 m
Connector
4 pin USB Type A - male
Connector (Second End)
4 pin USB Type A - female
USB / USB 2.0
P/N: SVA5H2NEUA, UUSBOTG
USB extension cable
Shielded
Plated Connector
Nickel
Length
20 m
Connector
USB / USB 2.0, FCC, RoHS
887W StarTech.com 10 ft USB 2.0 Certified A to B Cable - M/M In Stock £3.83
887W StarTech.com 20m USB 2.0 Active Extension Cable - M/F In Stock £58.83
887W StarTech.com 35m USB 2.0 Active Extension Cable - M/F In Stock £97.66
887W StarTech.com 15m USB 2.0 Active Extension Cable - M/F In Stock £46.99
Length: 20m
Price Range Ex VAT: 50 - 100
