Extend the distance between a computer and a USB 2.0 device by 20 meters. The USB2AAEXT20M 20-meter Active USB 2.0 Extension Cable, offers one USB type-A (male) connector and one USB type-A (female) connector, and provides an active extension of USB 2.0 devices of up to 20-meters (66-feet).
An all-in-one cable for overcoming distance restrictions as well as power source limitations, the active USB 2.0 extension cable incorporates bus-powered active circuitry to ensure performance beyond the length limits of standard USB cables. Up to 2 of these cables can be daisy-chained together, allowing the connection to be extended a total of 40-meters. If necessary, the USB device can be powered from a wall outlet using the Universal AC power adapter provided with the cable.
Durable construction
The cable features a robust shielded design, which minimizes interference and increases overall durability, ensuring a reliable connection for all devices. -
Active signal regeneration
With built-in signal regeneration technology, this cable maintains high-quality data transfer over long distances, ensuring minimal latency and performance. -
Versatile compatibility
Designed to comply with USB 2.0 standards, this cable is compatible with a wide range of USB devices, making it a versatile solution for applications.
- StarTech.com 20m USB 2.0 Active Extension Cable - M/F - USB extension cable - USB (M) to USB (F) - USB 2.0 - 66 ft - active - black - USB2AAEXT20M - USB extension cable - USB to USB - 20 m
- Technology
- Shielded
- Active cable (signal regeneration)
- Length
- 20 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 4 pin USB Type A - female
- USB / USB 2.0
- Black
- 2-year warranty
- Designed For
- P/N: SVA5H2NEUA, UUSBOTG
- Technology
- Shielded
- Plated Connector
- Nickel
- Length
- 20 m
- Black
- Connector
- USB / USB 2.0, FCC, RoHS
- 2-year warranty
- Designed For
StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F | In Stock | £5.02 |
StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £4.06 |
StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £4.29 |
StarTech.com 20m USB 2.0 Active Extension Cable - M/F | In Stock | £74.54 |
StarTech.com 15m USB 2.0 Active Extension Cable - M/F | In Stock | £59.10 |
StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad | In Stock | £14.46 |
StarTech.com 10m USB 2.0 Active Extension Cable - M/F | In Stock | £51.00 |
StarTech.com 25m USB 2.0 Active Extension Cable - M/F | In Stock | £90.27 |
StarTech.com 5m USB 2.0 Active Extension Cable - M/F | In Stock | £37.03 |
StarTech.com DC Power Adapter - 5V, 2A | In Stock | £9.67 |
StarTech.com USB Extender Hub, 24m, USB 2.0 | In Stock | £120.00 |
StarTech.com USB Extender Hub, 10m, USB 3.0 | In Stock | £116.04 |
