StarTech.com 20" USB C Cable 10Gbps Gen2
Quicklinx: GJX1WS00 Mfr#: USB31CCV50CM
Length: 50cm
33 In Stock
£13.14 ex VAT
£15.76 inc VAT
This USB 3.2/3.1 Gen 2 10Gbps USB-C cable lets you connect your USB Type-C devices for syncing, charging and powering your devices.
The cable is also compatible with Thunderbolt 3 ports, which means you can charge and sync your USB-C mobile devices using your Thunderbolt 3 laptop.
  • Power your USB-C devices
    With up to 5A (100W) of power delivery, you can power a USB-C laptop, such as your Apple MacBook or Microsoft Surface Book. Simply connect the cable to your USB-C laptop and to a USB-C wall charger. You can use this USB Type-C cable to power your USB-C hard drive from the USB-C port on your laptop. This cable is great for close-range connections to charge and sync your USB Type-C mobile devices with your laptop. You can also use the cable to charge your USB-C devices from a USB-C wall charger, car charger or power bank. It's the ideal cable for commuters for in-car use or to reduce clutter when syncing with your laptop.
  • Deliver 8K video with DisplayPort 1.4 Alt Mode
    The cable supports 8K 30Hz video with DisplayPort 1.4 and is backward compatible for connecting your docking station or laptop to a monitor that supports 4K or 1080p resolutions.
  • Keep as a spare while traveling
    Replace the USB-C charging cable that came with your device, or keep one as a spare while you're traveling, so that all of your devices will be ready to use whenever you need them while you're on the road.
StarTech 20" (50cm) USB C Cable 10Gbps, USB 3.1/3.2 Gen 2 Type-C Cable, 100W (5A) Power Delivery Charging, DP Alt Mode, USB-C to C Cord, For USB-C Laptop, Phone, Device, Charge/Sync - Thunderbolt 3 Compatible (USB31CCV50CM) - USB-C cable - USB-C to USB-C - 50 cm
USB-C cable
4K support, EMI protection, DisplayPort Alternate Mode support, Power Delivery (PD) technology, outer diameter 4.8 mm, 10 Gbps data rate
Cable Length
50 cm
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
USB 3.2 Gen 2 / DisplayPort 1.4 /Thunderbolt 3
Grey, black
P/N: DK30C2DAGPD, DK30C2HAGPD
USB-C cable
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
American Wire Gauge (AWG)
30/32
Plated Connector
Nickel
Cable Length
50 cm
Grey, black
Connector
24 pin USB-C - male
24 pin USB-C - male
USB 3.2 Gen 2 / DisplayPort 1.4 /Thunderbolt 3, RoHS, WEEE
Shipping Width
22 cm
Shipping Depth
12.8 cm
Shipping Height
14 cm
Shipping Weight
88 g
GJX1 StarTech.com Rugged Right Angle USB-C Cable 1m In Stock £28.64
GJX1 StarTech.com 3m Active USB-C Cable, USB 3.2 In Stock £48.60
Length: 50cm
