This 2-port KVM switch combines 4K 60Hz capabilities with control of two USB-C DP Alt-mode, Thunderbolt 3, or Thunderbolt 4 computers.
4K 60Hz Resolution
This 2-Port USB-C KVM switches between two USB-C enabled computers viewed over a single DisplayPort monitor. It supports up to 4K 60Hz (4:4:4) resolutions with 2x USB-A 480Mbps hub ports. This KVM is ideal for applications such as CAD/CAM, video editing, and content creation. Support for High Dynamic Range (HDR) offers increased contrast, brightness, colors, and greater luminosity. -
Analog and Digital Audio
This USB-C DisplayPort KVM Switch supports 2-channel analog and digital audio output, as well as microphone input, through 3.5mm or USB ports. This provides the user with centralized audio control through the KVM switch. Audio profiles are selectable with hot key commands. -
Intuitive Control
The front panel push button and hot key functions make it easy to switch between computers. Install host computers using a single USB-C cable to connect to the KVM. USB HID and USB Hub ports on the front and rear ensure convenient setup configuration and access to USB peripherals. The metal housing of the KVM Switch is suitable for many installation environments. This product is backed for 2-years by StarTech.com, including free 24/5 multi-lingual technical assistance.
- StarTech.com USB C KVM Switch, 2 Port DisplayPort KVM w/ 4K 60Hz UHD HDR Video, 3.5mm Audio, USB Type C KVM Switch, 4x USB HID and 2x USB A 3.2 Gen 1 5Gbps Hub, Thunderbolt 3/4 Compatible - Hot Key Switching (SV231DPUCA) - KVM / audio / USB switch - 2 ports - TAA Compliant
- Subtype
- KVM
- Ports
- 2 x KVM / audio / USB
- Auto Scan Mode, metal housing, Pushbutton/Hotkey switching, HDR 4K60 4:4:4 compatible, 4K UHD video streaming, USB HID Transport, 2.1 channel audio support, video mode switch
- USB 1.1, HDCP 2.2, USB 3.2 Gen 1
- Power
- AC 100-240 V 1.2 A
- 14 cm x 16 cm x 4 cm
- 600 g
- TAA Compliant
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 4K @ 60 Hz
- Status Indicators
- Select
- 1 x DisplayPort output , 2 x USB 3.2 Gen 1 Type A , 4 x USB 1.1 Type A , 2 x USB Type C host , 1 x headphones mini-jack , 1 x microphone mini-jack
- Power Device
- External power adapter
- Power Provided
- DC 12 V - 3 A
- Voltage Required
- AC 100-240 V
- Electric Current Required
- 1.2 A
- Included Accessories
- Rubber feet set
- MTBF
- 158,000 hours
- FCC Part 15, RoHS, WEEE, RCM, Thunderbolt 3, Thunderbolt 4, DisplayPort 1.2 (Alt Mode)
- TAA Compliant
- 14 cm
- 16 cm
- 4 cm
- 600 g
- Shipping Width
- 18.4 cm
- Shipping Depth
- 23.8 cm
- Shipping Height
- 8.9 cm
- Shipping Weight
- 1 kg
- Limited warranty - 2 years , Technical support - assistance - lifetime
- 0 °C
- 40 °C
- 0 - 80% RH
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 60 °C
StarTech.com 2 Port USB C KVM Switch | In Stock | £77.13 |
StarTech.com 3ft DisplayPort 1.4 8K 60Hz | In Stock | £14.40 |
StarTech.com 6ft DisplayPort 1.4 8K 60Hz | In Stock | £14.98 |
StarTech.com 3ft USB C Cable 10Gbps Gen2 | In Stock | £15.43 |
StarTech.com 20" USB C Cable 10Gbps Gen2 | In Stock | £13.14 |
StarTech.com 2 Port Hybrid USB-C KVM Switch | In Stock | £34.40 |
StarTech.com USB-C KVM Switch, 4K 60Hz | In Stock | £150.27 |
