StarTech.com Rugged Right Angle USB-C Cable 1m
Quicklinx: HFP5WS00 Mfr#: RUSB31CC1MBR
Length: 1m
20 In Stock
£27.51 ex VAT
£33.01 inc VAT
Connect USB 10Gbps source and peripheral devices, using this 3.3ft (1m) Rugged Right Angle USB Type-C Cable. Position the right angle USB-C connection along the device to reduce cable clutter and avoid prolonged strain from bending. It is ideal for 10Gbps data transfer to external USB-C-enabled external storage devices, or as a single-cable connection from a USB-C dock to a laptop.
  • Experience 4K Video with DisplayPort 1.2 Alt Mode
    The Rugged USB-C cable supports up to 4K 60Hz video over DisplayPort 1.2 Alt Mode, and is compatible with 1080p and lower resolutions.
  • Enhanced Durability
    Designed to withstand heavy use, the USB-C cable features an Aramid fiber core and durable TPE outer jacket. This heavy-duty construction protects against fraying or breakage and resists tangling.
  • Full-Featured USB-C Power and Data
    This USB Type-C cable features Power Delivery (PD) 3.0 with up to 100W PD output. Power and charge a USB-C laptop, such as Apple MacBook, Lenovo ThinkPad, or Microsoft Surface with up to 100W output over USB Power Delivery 3.0. Connect the USB-C cable from a laptop to a USB-C wall charger or docking station.
StarTech.com 3ft (1m) Rugged Right Angle USB-C Cable, USB 10 Gbps, USB C to C Data Transfer Cable, 4K 60Hz DP Alt Mode, 100W Power Delivery - 90 Degree USB-C Cable (RUSB31CC1MBR) - USB-C cable - 24 pin USB-C to 24 pin USB-C - 1 m
USB-C cable
Shielded
Passive adapter, 4K60Hz support, rugged, strain relief, halogen free, e-marker chip, up to 100 Watts of power delivery, 10 Gbps data rate, DisplayPort Alternate Mode 1.2 support
Length
1 m
Connector
24 pin USB-C - male - straight
Connector (Second End)
24 pin USB-C - male - right-angled
USB 3.2 Gen 2
USB-C cable
Shielded
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
Plated Connector
Gold, nickel
Length
1 m
Outside Diameter
4.8 mm
Connector
USB 3.2 Gen 2, RoHS, WEEE, EMI
Shipping Width
12.8 cm
Shipping Depth
22 cm
Shipping Height
1.4 cm
Shipping Weight
95 g
Length: 1m
