StarTech.com 2 Pt DisplayPort KVM
Quicklinx: DWZRWS00 Mfr#: SV231DPU34K
Type: KVM / audio / USB switch
Connectivity: KVM
Ports: 2
£301.49 ex VAT
£361.78 inc VAT
This 2-port KVM switch combines 4K (60Hz) digital display capabilities with control of two connected computers.
The DisplayPort KVM switch supports resolutions up to 4K at 60Hz.Itdrivesone large monitor at the full 4K resolution or, using an MST adapter, can drive various DisplayPort multi-display setups totaling 4Kif you need to maximize viewing space. With support for digital audio (with supporting displays and sources)and separate 3.5 mm stereo audio, the DisplayPort 1.2 KVM switch delivers full audio compatibility.
The integrated USB 3.0 hub shares two peripherals (in addition to keyboard and mouse) among attached computers as if they were directly connected to your host computer, eliminating the cost of duplicate devices such as printers and scanners.
While supporting Windows, this DP KVM switch is also compatible with Mac and Linux operating systems.
The front-panel pushbuttons make it easy to switch between systems and activate the auto scan feature. The hotkey functionality makes accessing each system quickly, while a buzzer sound confirms the switch.
StarTech.com offers a wide selection of high-quality KVM switches and KVM-related products to help you access your systems more efficiently without the expense and clutter of extra keyboards, mice, and monitors.
  • 4K60 picture and full audio support
    The DisplayPort KVM switch supports resolutions up to 4K at 60 Hz. It drives one large monitor at the full 4K resolution or, using an MST adapter, can drive various DisplayPort multi-display setups totaling 4K if you need to maximize viewing space. With support for digital audio (with supporting displays and sources) and separate 3.5 mm stereo audio, the DisplayPort 1.2 KVM switch delivers full audio compatibility.
  • Integrated USB hub
  • Easy to operate
StarTech.com 2 Port DisplayPort KVM Switch, 4K 60Hz, Single Display, Dual Port UHD DP 1.2 USB KVM Switch with Integrated USB 3.0 Hub and Audio, Dell, HP, Apple, Lenovo, TAA Compliant - Keyboard/Video/Mouse Switch (SV231DPU34K) - KVM / audio / USB switch - 2 ports - TAA Compliant
Subtype
KVM
Ports
2 x KVM / audio / USB
4K resolution support, MST support
Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
TAA Compliant
Enclosure Type
Desktop
Subtype
KVM
Ports
Keyboard / Mouse Interface
USB
Max Resolution
60 Hz
Status Indicators
Status
1 x DisplayPort output , 2 x DisplayPort input , 1 x audio output mini-jack , 2 x audio input mini-jack , 4 x keyboard (USB) / mouse (USB) Type A , 2 x USB 3.0 Type B , 2 x USB 3.0 Type A
External power adapter
4 rubber feet
DisplayPort 1.2
TAA Compliant
DWZR StarTech.com 4 Port USB DisplayPort KVM Switch with Audio In Stock £246.14
DWZR StarTech.com DisplayPort USB KVM Switch In Stock £230.07
DWZR StarTech.com 1U Rackmount Brackets for KVM Switch (SV431 Series) In Stock £22.32
DWZR StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £13.58
DWZR StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.37
DWZR StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.56
DWZR StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £2.97
DWZR StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.97
DWZR StarTech.com Multi Stream Transport Hub – DisplayPort 1.2 to Triple Head DisplayPort MST Hub In Stock £37.96
DWZR StarTech.com 3m 10ft USB 3.0 A to A Cable In Stock £7.29
DWZR StarTech.com 4-Port DisplayPort KVM Switch With Built-in USB 3.0 Hub - Rack-Mountable In Stock £351.01
DWZR StarTech.com 2 Port Dual DP KVM Switch - 4K In Stock £251.98
DWZR StarTech.com 4 Port DisplayPort KVM Switch 4K 60Hz In Stock £336.44
DWZR StarTech.com 4PT Dual DP KVM Switch 4K60 In Stock £583.16
DWZR StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £13.72
DWZR StarTech.com 2 Port USB C KVM Switch In Stock £77.13
DWZR StarTech.com 2 Port Triple Monitor DisplayPort KVM Switch In Stock £360.65
DWZR StarTech.com 2 Port Quad Monitor DisplayPort KVM Switch In Stock £461.44
DWZR StarTech.com 2 Port Hybrid USB-C KVM Switch In Stock £32.88
DWZR StarTech.com 2-Port DP KVM Switch, 8K 60Hz In Stock £305.16
DWZR StarTech.com 4-Port DP KVM Switch, 8K 60Hz In Stock £378.68
Connectivity: KVM
Ports: 2
