StarTech.com 2 Port USB 3.0 A Female Slot Plate Adapter
Quicklinx: 7TH1WS00 Mfr#: USB3SPLATE
Hurry, only 3 left in stock!
£18.52 ex VAT
£22.22 inc VAT
The USB3SPLATE 2-port USB 3.0 A slot plate converts the USB pins on the USB 3.0 motherboard header to 2 standard USB 3.0 A-type ports. The plate can be mounted on the rear panel of a computer case, adding two USB 3.0 A female ports for simple connection to USB peripheral devices.
The USB 3.0 standard supports transfer rates of up to 5Gbps, and provides connectivity and support for older USB 2.0 (480Mbps) and 1.1 (12Mbps) devices.
  • Convenient expansion capabilities
    This adapter allows for the addition of two USB Type-A female ports to your system, enhancing connectivity options for external devices.
  • Reliable data transmission
    With double shielded technology, this adapter minimizes interference, ensuring stable and high-speed data transfer for connected devices.
  • Easy installation process
    The inclusion of a 20-pin IDC header simplifies installation, making it user-friendly for integrating additional USB ports.
  • Environmentally friendly design
    This product is RoHS compliant, reflecting a commitment to reducing hazardous substances and promoting an eco-conscious choice.
StarTech.com 2 Port USB 3.0 A Female Slot Plate Adapter - USB 3.0 motherboard Adapter - USB 3 plate - USB 3.0 header Adapter (USB3SPLATE) - USB panel - USB Type A to 20 pin IDC - 50 cm
USB panel
Double shielded
Length
50 cm
Connector
2 x 9 pin USB Type A - female
Connector (Second End)
20 pin IDC - female
USB / USB 2.0 / USB 3.0
Blue
P/N: PEXUSB312A1C1H, PEXUSB312A2C2V, PEXUSB312EIC
USB panel
Double shielded
American Wire Gauge (AWG)
28
Length
50 cm
Blue
Connector
20 pin IDC - female
USB / USB 2.0 / USB 3.0, RoHS
7TH1 StarTech.com 2 Port USB A Female Slot Plate Adapter In Stock £6.18
7TH1 StarTech.com 2 Port USB A Female Low Profile Slot Plate Adapter In Stock £6.75
7TH1 StarTech.com 1 ft Panel Mount USB Cable A to A - F/M In Stock £4.92
7TH1 StarTech.com 2 Port USB 3.0 A Female Slot Plate Adapter In Stock £18.52
7TH1 StarTech.com 2 Port Panel Mount USB 3.0 Cable - USB A to Motherboard Header Cable F/F In Stock £13.66
7TH1 StarTech.com 4 Port USB A Female Slot Plate Adapter In Stock £7.61
