StarTech.com 2 Port Panel Mount USB 3.0 Cable - USB A to Motherboard Header Cable F/F
Quicklinx: 7X1GWS00 Mfr#: USB3SPNLAFHD
Length: 50cm
More than 50 In Stock
£16.43 ex VAT
£19.71 inc VAT
Extend a USB 3.0 Motherboard Header into Two Panel-mount USB 3.0-A Ports. The USB3SPNLAFHD 2-Port USB 3.0 to Panel mount USB cable features a 20-pin USB 3.0 motherboard header connection on one end, breaking off into two separate USB 3.0-A (female) ports on the other end of the cable.
The USB 3.0 panel mount cable offers a convenient solution for connecting bootable thumb drives or authentication fobs etc. to the motherboard USB 3.0 connection.
StarTech.com 2 Port Panel Mount USB 3.0 Cable - USB A to Motherboard Header Cable F/F (USB3SPNLAFHD) - USB internal to external cable - USB Type A to 20 pin IDC - 50 cm
Shielded
Length
50 cm
Connector
2 x 9 pin USB Type A - female
Connector (Second End)
20 pin IDC - female
USB 3.0
Blue
Shielded
American Wire Gauge (AWG)
28
Length
50 cm
Blue
Connector
20 pin IDC - female
USB 3.0, RoHS
7X1G StarTech.com 2 Port USB 3.0 A Female Slot Plate Adapter In Stock £18.98
7X1G StarTech.com 2 Port Panel Mount USB 3.0 Cable - USB A to Motherboard Header Cable F/F In Stock £16.43
Length: 50cm
