The USB3SPLATE 2-port USB 3.0 A slot plate converts the USB pins on the USB 3.0 motherboard header to 2 standard USB 3.0 A-type ports. The plate can be mounted on the rear panel of a computer case, adding two USB 3.0 A female ports for simple connection to USB peripheral devices.
The USB 3.0 standard supports transfer rates of up to 5Gbps, and provides connectivity and support for older USB 2.0 (480Mbps) and 1.1 (12Mbps) devices.
Convenient expansion capabilities
This adapter allows for the addition of two USB Type-A female ports to your system, enhancing connectivity options for external devices. -
Reliable data transmission
With double shielded technology, this adapter minimizes interference, ensuring stable and high-speed data transfer for connected devices. -
Easy installation process
The inclusion of a 20-pin IDC header simplifies installation, making it user-friendly for integrating additional USB ports. -
Environmentally friendly design
This product is RoHS compliant, reflecting a commitment to reducing hazardous substances and promoting an eco-conscious choice.
- StarTech.com 2 Port USB 3.0 A Female Slot Plate Adapter - USB 3.0 motherboard Adapter - USB 3 plate - USB 3.0 header Adapter (USB3SPLATE) - USB panel - USB Type A to 20 pin IDC - 50 cm
- USB panel
- Technology
- Double shielded
- Length
- 50 cm
- Connector
- 2 x 9 pin USB Type A - female
- Connector (Second End)
- 20 pin IDC - female
- USB / USB 2.0 / USB 3.0
- Blue
- Limited lifetime warranty
- Designed For
- P/N: PEXUSB312A1C1H, PEXUSB312A2C2V, PEXUSB312EIC
- USB panel
- Technology
- Double shielded
- American Wire Gauge (AWG)
- 28
- Length
- 50 cm
- Blue
- Connector
- USB / USB 2.0 / USB 3.0, RoHS
- Designed For
StarTech.com 2 Port USB A Female Slot Plate Adapter | In Stock | £6.10 |
StarTech.com 2 Port USB A Female Low Profile Slot Plate Adapter | In Stock | £7.22 |
StarTech.com 1 ft Panel Mount USB Cable A to A - F/M | In Stock | £5.29 |
StarTech.com 2 Port USB 3.0 A Female Slot Plate Adapter | In Stock | £18.98 |
StarTech.com 2 Port Panel Mount USB 3.0 Cable - USB A to Motherboard Header Cable F/F | In Stock | £16.43 |
StarTech.com 4 Port USB A Female Slot Plate Adapter | In Stock | £7.58 |
