StarTech.com 2 Port USB A Female Low Profile Slot Plate Adapter
Quicklinx: 6BBQWS00 Mfr#: USBPLATELP
30 In Stock
£7.22 ex VAT
£8.66 inc VAT
Add two external USB 2.0 ports to your small form factor PC. The USBPLATELP 2 Port Low Profile USB Bracket converts the USB pins on a USB 2.0 motherboard header to 2 standard USB A ports.
An ideal solution for small form factor computer cases, the slot plate can be mounted on the rear panel of your low profile or thin client computer case - adding two USB female ports for simple connection to USB peripheral devices.
StarTech.com 2 Port USB A Female Low Profile Slot Plate Adapter - 2 Port USB Bracket - USB 2.0 A Female (USBPLATELP) - USB panel - USB to 5 pin in-line
USB panel
Connector
2 x 4 pin USB Type A - female
Connector (Second End)
2 x 5 pin in-line - female
USB panel
Connector
6BBQ StarTech.com 2 Port USB 3.0 A Female Slot Plate Adapter In Stock £18.98
6BBQ StarTech.com 4 Port USB A Female Slot Plate Adapter In Stock £7.58
