StarTech.com 2 Port SATA 6 Gbps PCI Express SATA Controller Card
Quicklinx: 72H8WS00 Mfr#: PEXSAT32
The PEXSAT32 2-Port PCI Express SATA 6 Gbps (SATA 3.0) Controller Card offers simple connectivity between a host computer and SATA 3.0 devices - a cost-effective solution for connecting high-speed storage, such as High RPM Hard Drives and Solid State Drives (SSD), which in turn allows for easier data backups and archiving.
With full support for SATA 3.0 hard drives and data transfer speeds of up to 6 Gbps, the adapter card features a native PCI Express single chipset that provides enhanced compatibility, reliability and performance for external SATA 600 MB/s storage needs.
The controller card is backward compatible with SATA 2.0 devices, providing the versatility to use older storage, and features port multiplier capability with command-based and FIS-based switching for connecting multiple external hard drives to a host PC through a single external SATA connection.
A dual profile solution, the SATA 3.0 controller card includes a low profile bracket for installation in slimline or small form factor computer cases.
StarTech.com 2 Port SATA 6 Gbps PCI Express SATA Controller Card - Dual Port PCIe SATA III Card Adapter (PEXSAT32) - storage controller - SATA 6Gb/s - PCIe
Storage controller - plug-in card
Bus Type
PCIe
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive
Channel Qty
2
Max Storage Devices Qty
2
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Apple MacOS X 10.6 - 10.14, Linux 3.5.x - 4.11.x LTS versions only
64.5 cm x 67.7 cm x 21.3 cm
67.9 g
P/N: ST521PMINT
Host Bus
PCIe
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive
Channel Qty
2
2
Marvell 88SE9128
2 x SATA 6Gb/s - SATA
Compatible Slots
1 x PCI Express
WHQL, FCC, RoHS
Limited warranty - lifetime
64.5 cm
67.7 cm
21.3 cm
67.9 g
P/N: ST521PMINT
72H8 StarTech.com 24" Serial ATA Cable In Stock £5.28
72H8 StarTech.com 18in SATA Serial ATA Cable In Stock £2.50
72H8 StarTech.com 36in SATA Serial ATA Cable In Stock £5.70
72H8 StarTech.com 12in Latching SATA Cable In Stock £6.16
72H8 StarTech.com 18in Latching SATA Cable In Stock £4.24
72H8 StarTech.com 24in Latching SATA Cable In Stock £6.84
72H8 StarTech.com 2 Port PCI Express SATA 6 Gbps eSATA Controller Card - 2 Int/2 Ext In Stock £27.49
72H8 StarTech.com 4 Port PCI Express 2.0 SATA III 6Gbps RAID Controller Card with HyperDuo SSD Tiering In Stock £69.40
72H8 StarTech.com 18in Right Angle SATA Cable In Stock £4.34
