Add 4 Internal SATA III (6Gbps) ports to a computer through a PCI Express x2 slot. The PEXSAT34RH 4-Port PCI Express 2.0 SATA Controller Card with HyperDuo adds 4 AHCI SATA III ports to a computer through a PCIe slot (x2), delivering multiple internal 6Gbps connections for high-performance hard drives and Solid State Drives (SSDs).
Featuring HyperDuo technology, the SATA card offers SSD auto-tiering which lets you balance the performance advantages of SSD storage with the cost-effectiveness and large capacity of standard hard drives. By combining SSD and HDD drives into a single volume (up to 3 SSD + 1 HDD), HyperDuo discreetly works in the background to identify and move frequently accessed files to the faster SSD drive(s) for improved data throughput - up to 80% of SSD performance! (Note: The HyperDuo automatic storage tiering feature is compatible with computers that use a BIOS.)
The PCIe SATA controller card supports Port Multiplier (PM), enabling multiple SATA drives to be connected to one port over a single cable, for a total of 7 drives (Up to 4 drives through PM on one port, and a single drive to the remaining 3 ports). Plus, the SATA controller card offers an effective hardware RAID solution, with native RAID (0, 1, 1+0) support.
Versatile RAID support
This controller card supports various RAID levels including RAID 0 for performance, RAID 1 for data redundancy, RAID 10 for a combination of both, and JBOD for flexible storage management. -
High-speed data transfer
With a data transfer rate of 6 Gbit/s, this card allows for rapid data movement, optimizing overall system performance during heavy workloads. -
Compact and efficient design
The low-profile form factor enables easy installation in space-constrained environments without sacrificing performance, providing a fit for compact systems. -
Broad compatibility
Tailored for Mac systems, this storage controller ensures seamless integration, allowing users to expand their storage without complications. -
Reliable standards compliance
Meets FCC and RoHS standards, assuring users of environmental and safety while delivering consistent performance.
- StarTech.com 4 Port PCI Express 2.0 SATA III 6Gbps RAID Controller Card with HyperDuo SSD Tiering - PCIe SATA 3 Controller Adapter (PEXSAT34RH) - storage controller (RAID) - SATA 6Gb/s - PCIe 2.0 x2
- Storage controller (RAID) - plug-in card - low profile
- Bus Type
- PCIe 2.0 x2
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 6 Gbit/s
- Supported Devices
- Disk array (RAID)
- Channel Qty
- 4
- RAID Level
- RAID 0, RAID 1, RAID 10, JBOD
- System Requirements
- Linux, Apple MacOS X 10.6, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Windows 10 (32/64 bits)
- 12 cm x 7 cm x 2 cm
- 49 g
- 2-year warranty
- Designed For
- P/N: ST521PMINT
- Host Bus
- PCIe 2.0 x2
Storage Controller
- Interface
- SATA 6Gb/s
- 6 Gbit/s
- Supported Devices
- Disk array (RAID)
- Channel Qty
- 4
- RAID Level
- Processor
- Marvell 88SE9230
- 4 x SATA 6Gb/s - SATA (internal)
- Included Accessories
- Low-profile bracket
- FCC, RoHS
- OS Required
- Limited warranty - 2 years
- 12 cm
- 7 cm
- 2 cm
- 49 g
- 5 °C
- 50 °C
- 20 - 80% (non-condensing)
- Designed For
- P/N: ST521PMINT
StarTech.com 18" Serial ATA Cable w/R Angle | In Stock | £5.00 |
StarTech.com 12in Latching SATA Cable | In Stock | £6.16 |
StarTech.com 18in Latching SATA Cable | In Stock | £4.24 |
StarTech.com 8in Latching SATA to SATA Cable - F/F | In Stock | £5.44 |
StarTech.com 4 Port PCI Express 2.0 SATA III 6Gbps RAID Controller Card with HyperDuo SSD Tiering | In Stock | £66.34 |
StarTech.com 2x M.2 SSD Controller - PCIe | In Stock | £21.26 |
StarTech.com 3PT M.2 SSD Card - PCIe 3.0 | In Stock | £28.55 |
