Convert a Mini PCI Express Card into a Standard Desktop PCI Express Card. The PEX2MPEX PCI Express to Mini PCI Express Adapter Card enables Mini PCI Express cards (Mini Cards) to be used in a standard PCI Express card slot. These PCIe Mini Cards, which are typically designed for laptops or small form factor ITX computers, can be used normally inside more conventional desktop computers. The adapter card features a complete PCIe to Mini PCIe pass-through design that eliminates data transfer rate bottlenecks, while the included full and low profile installation brackets makes this adapter card compatible with most computer chassis.
- StarTech.com PCI Express to Mini PCI Express Card Adapter - Mini PCI card adapter - PCIe - PEX2MPEX - Mini PCI card adapter - PCIe
- Interface Type
- PCIe
- 2 cm x 7.4 cm x 6.8 cm
- 200 g
- OS Required
- Microsoft Windows 7, Microsoft Windows Vista
- 2-year warranty
- Interface Type
- PCIe
- 2 cm
- 7.4 cm
- 6.8 cm
- 200 g
- Expansion Slots
- 1 x mini PCI
- 1 x USB - 4 pin USB Type B - internal
- Compatible Slots
- 1 x PCI Express
- FCC, RoHS
- OS Required
- Limited warranty - 2 years
- 0 °C
- 55 °C
- 5 - 95% (non-condensing)
StarTech.com PCI Express to PCI Adapter Card | In Stock | £36.30 |
