Install half-height/low profile x1 PCI Express interface cards in a standard PCI expansion slot. The PCI1PEX1 PCI to PCI Express Adapter card lets you use low profile PCIe expansion cards in a server/desktop motherboard PCI slot. The adapter connects through a 32-bit PCI slot to provide a low profile PCIe x1 slot in its place; a spare, full size bracket is included for installation in larger desktop or server expansion slots that can accommodate a full-sized card.
The PCI to PCI Express Adapter features an innovative bracket design that adapts and secures the low profile PCI Express card into the converted slot, ensuring a versatile and economical solution for extending the usability of older PCI motherboards or using low profile PCIe cards that do not have PCI equivalents.
- StarTech.com PCI to PCI Express Adapter Card - PCIe x1 (5V) to PCI (5V & 3.3V) slot adapter - Low Profile - PCI1PEX1 - PCIe x1 to PCI slot adapter
- Product Type
- 6 cm x 13.5 cm x 2 cm
- 27 g
- System Requirements
- Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows 2000/XP/Vista/7
- 2-year warranty
- Product Type
- 6 cm
- 13.5 cm
- 2 cm
- 27 g
- FCC, RoHS
- OS Required
- Limited warranty: - 2 years
- 0 °C
- 85 °C
StarTech.com PCI Express to PCI Adapter Card | In Stock | £37.99 |
StarTech.com PCI Express X1 to X16 Low Profile Slot Extension Adapter | In Stock | £22.76 |
