StarTech.com 2-Port 10Gb PCIe Network Card
Quicklinx: F6TLWS00 Mfr#: ST10GSPEXNDP
Wired / Wireless: Wired
Protocol: Fast Ethernet, Gigabit Ethernet, 10 Gigabit Ethernet
Form Factor: Plug-in card
Type: Network adapter
£229.03 ex VAT
£274.83 inc VAT
This dual-port 10Gb PCIe network card offers a versatile and low-cost way to deploy 10GbE network connectivity. It adds two copper Ethernet ports to your server or desktop computer and provides Multi-Gigabit Ethernet access to your network at five speeds: 10G, 5G, 2.5G, 1G and 100Mbps.
The 10GBASE-T NIC provides additional bandwidth using your existing Ethernet infrastructure to help reduce the cost of cabling upgrades. The card enables you to connect to 10GBASE-T and NBASE-T equipment at network speeds of: 100Mbps, 1Gbps, 2.5Gbps or 5Gbps over your CAT5e cabling (up to 100 m); 10Gbps over your CAT6 or better cabling (up to 100 m).
The network adapter card adds two Ethernet ports to your workstation through an x8 PCIe 2.X (or higher) slot. It features 10GBASE-T technology, supporting advanced Multi-Gigabit systems, including Cisco campus switches and Aruba Networks access points. The NIC card also supports additional features including 9K Jumbo Frames, Autonegotiation, Auto-MDIX and 802.1q VLAN tagging.
The dual Tehuti TN4010 + Marvell 88X3110 chipset, compliant with IEEE 802.3az, ensures peak operation and reduced power consumption. The decreased consumption minimizes the heat generated to avoid operating temperatures increasing within your server case.
StarTech.com Dual Port 10G PCIe Network Adapter Card, Tehuti TN4010 10GBASE-T & NBASE-T PCI Express Network Interface Adapter 10/5/2.5/1GbE Multi Gigabit Ethernet 5 Speed NIC LAN Card - Network Adapter Card (ST10GSPEXNDP) - network adapter - PCIe 2.0 x8 - 10Gb Ethernet x 2
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express 2.0 x8
PCI Specification Revision
PCIe 2.0
Ports
10Gb Ethernet x 2
Cabling Type
Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 10GBase-T
100Mb LAN, GigE, 10 GigE
Data Transfer Rate
10 Gbps
Network / Transport Protocol
TCP/IP, UDP/IP, iSCSI
IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3an, IEEE 802.3az
VMware ESXi 5.1, VMware ESXi 5.0, Microsoft Windows 7 / 8 / 8.1 / 10, VMware ESXi 6.0, VMware ESXi 6.5, Microsoft Windows Hyper-V Server, Microsoft Windows Server 2008 / 2012 R2, Linux 3.x - 4.11 LTS versions, Microsoft Windows Server 2012 R2 / Windows Server 2016, Apple macOS 10.12 - 10.14
Network adapter
Plug-in card
PCI Express 2.0 x8
PCIe 2.0
Ports
10Gb Ethernet x 2
Wired
Cabling Type
Data Transfer Rate
10 Gbps
Status Indicators
Link/activity, link/speed
Auto-uplink (auto MDI/MDI-X), full duplex mode, tagged VLAN, 9 KB Jumbo Frame, promiscuous mode
2 x 10GBase-T - RJ-45
Low-profile bracket
Software Included
Drivers & Utilities
5 °C
50 °C
20 - 80%
F6TL StarTech.com 10G PCIe Network Adapter Card In Stock £124.73
F6TL StarTech.com 10G PCIe Network Adapter Card In Stock £120.03
F6TL StarTech.com 2-Port 2.5G PCIe Network Card In Stock £121.39
Protocol: Gigabit Ethernet
Protocol: 10 Gigabit Ethernet
