This dual-port 2.5 GbE network interface card (NIC) features an Intel I225-V chipset with Intel vPro technology, to enhance performance and data integrity across two 2.5G Ethernet connections. Utilize existing Cat5e or CAT6 cabling infrastructure while adding NBASE-T (802.3bz) compatibility for seamless integration.
IT manageability
Intel vPro for remote management and troubleshooting, PXE boot enabled to deployment speeds/updates, 9K jumbo frame for reduced packet overhead, remotely boot a system using WoL, VLAN support for efficient network management. -
Build quality
LAN card features: built-in heatsink to keep controller chips running cool and for optimal performance, LED indicators for link status/speed, LAN transformers maintain signal quality and reduced EMI for reliable communication. -
Increased network speed
The PCIe network card leverages Intel vPro technology for remote management and troubleshooting capabilities. Improve bandwidth for data-intensive applications, network sharing, FTPs, online or local storage/backup, and the streaming of online content - while reducing network slowdowns. Access up to 2.5GBASE-T speeds using Cat5e (or better) cabling, to maximize existing networks and equipment. -
Enhance existing hardware
The network interface card connects via an available x2 PCI Express 2.0 (or higher) expansion slot. The card ships in a standard-profile bracket and includes a low-profile bracket for installation into small form factor systems and servers.
- StarTech.com 2-Port 2.5Gbps NBASE-T PCIe Network Card, Intel I225-V, Dual-Port Computer Network Card, Multi-Gigabit NIC, PCI Express Server LAN Card, Desktop Ethernet Interface - network adapter - PCIe 2.0 x2 - 10M/100M/1G/2.5 Gigabit Ethernet x 2
- Network adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express 2.0 x2
- PCI Specification Revision
- PCIe 2.0
- Ports
- 11 cm x 12 cm x 1.8 cm
- 60 g
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 2.5GBase-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE, 2.5GbE
- Data Transfer Rate
- 2.5 Gbps
- Capacity
- Jumbo frame size: 9000
- Processor
- Intel I225-V
- IEEE 802.3bz, IEEE 1588v1, IEEE 802.1as, IEEE 802.1p, IEEE 802.1Q, IEEE 802.1x, IEEE 802.3ab, IEEE 802.3i, IEEE 802.3u, IEEE P802.3az
- Black
- System Requirements
- Microsoft Windows 10 / 11, Microsoft Windows Server 2019, Microsoft Windows Server 2022, Linux 5.8.x or later (LTS versions only)
- 2-year warranty
- Network adapter
- Form Factor
- PCIe 2.0
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- Ethernet, Fast Ethernet, Gigabit Ethernet, 2.5 Gigabit Ethernet
- 2.5 Gbps
- Capacity
- Status Indicators
- Link/activity/speed
- PXE boot, Intel vPro Technology support, full duplex capability, Auto MDIX, auto-negotiation, VLAN support, WOL, bus powered
Processor / Memory
- Processor
- Intel I225-V
- 2 x 2.5 GBase-T - RJ-45
- Included Accessories
- Low-profile bracket
- RCM, WEEE, IEEE 1588
- Black
- OS Required
- 11 cm
- 12 cm
- 1.8 cm
- 60 g
- Limited warranty - 2 years , Technical support - assistance - lifetime
- 0 °C
- 55 °C
- 5 - 90% RH
StarTech.com 4-Port RJ45 1G OCP 3.0 NIC | In Stock | £256.92 |
